TODAYS SEAT TIME
/ TODAYS SEAT TIME #13,921
It was a pretty nice day here today to get some things around here done, and I made a little money today too,
It's always nice to make a few easy bucks!
SR
/ TODAYS SEAT TIME #13,923
Nice cool morning for mowing. Summer is here. 100º yesterday. Time to get ready for fire season....be safe out there
/ TODAYS SEAT TIME #13,925
^^^^ I played with my dozer yesterday. Must be something in the air.
Over the years the frost has pushed up a large rock in our road/driveway.
Yesterday was the day to remove it. I used my 1990 70 hp TD7G to push it out and off the road. It set my camera out and made a video.
After getting the rock out I recovered the displaced gravel and used it to fill the crater best I could. I packed it as I went with the tracks then smoothed off the area and packed it some more.
Here is the video. I work slow and easy.
Then i raked a yard of new gravel off the one-ton and packed it with the truck.
gg
/ TODAYS SEAT TIME #13,926
gg
Bravo! What a fine looking dozer and drive repair. Who needs Hollywood, I could watch this all night!
/ TODAYS SEAT TIME #13,927
My seat time yesterday, was loading logs onto my BSM and hauling slab wood away from it. I have a few old logs that should have been milled long time ago, so I loaded one of them on the BSM,
This one is a pretty nice cherry, and it did turn out some decent lumber even with the split ends that I probably should have sawn off,
I set the first side lumber aside to be "edged" later, the slab wood gets cut to length and goes into my firewood boxes,
And here's those boards getting edged,
After that, it's rinse and repeat, for the next log.
SR
/ TODAYS SEAT TIME #13,928
2520 moved some concrete mix for a small job, then performed a funerary escort for a hapless deer which had been hit by a car and expired in our front yard.
Was happy to have the 42" pallet forks...the more distance between me and that thing, the better.
/ TODAYS SEAT TIME #13,929
^^^ Last fall I was returning home from a morning fishing in a friend's truck. The car in front of us was from Canada and we saw it hit a deer, a button buck, that suddenly ran across the road. The woman was all upset. We told her no problem, we would take care of it. I dragged it off the road while my friend called fish and game to report the situation and get permission to keep the deer. We threw it in his truck. He said it was good eating, hardly any blood shot meat just heavy organ damage.
gg
/ TODAYS SEAT TIME #13,930
gg
The buzzards had already started tenderizing this beast even though it was only hit the night before, so I didn't want to waste any time gettting it out of there.
/ TODAYS SEAT TIME #13,931
Don't blame you - This isn't a good time of year to consider salvaging road kill especially if it laid there over night. For some reason your post just brought that story to mind.
gg
/ TODAYS SEAT TIME #13,932
Don't try this at home, kids: Used the rear blade on the loader to work the compost pile - and the bucket for some clean-up work, etc.
/ TODAYS SEAT TIME #13,934
Another really nice day out today, and one of today's jobs was to mill another older Cherry log, so I loaded one on the mill with my tractor. Once I opened it up, it was pretty nice inside,
Here's the slab wood that came off it, I turned it all into firewood,
I ended up with a pretty nice pile of Cherry,
Then it was off to cleaning some tree's out of the edge of my hayfields!
SR
/ TODAYS SEAT TIME #13,935
I hear ya SawyerBob. I bush-hogged 20A this evening and counted 9 big trees storms(1tornado) took down this spring. Two big Walnut trees blew down/were uprooted last Jan. Both fell on my old pole barn. Cleaning them up I'll leave to a professional, they fell across a creek and the main trunk of both is about 5' above the creek. The other 7 are on the other side of a different creek, which can't be driven across with tractor until this fall during the dry season. I have to drive into the creek, then up the creek to where I can drive over the other bank.
I still haven't figured out how to pull logs out, because that creek is just wide enough for my tractor, and pulling them straight across presents its own problems.
/ TODAYS SEAT TIME #13,936
I had a section of drive/road where I couldn't grade out the wheel ruts any more, So today I tail gate spread from the one-ton 4 loads, 12.6 ton, of 3/4" Stay-Mat over 350' of road.
Then I shaped it with the back of my rear blade to make an even crown.
Last I packed it with the one-ton. Couldn't quite reach a narrow strip in the center.
gg
/ TODAYS SEAT TIME #13,937
That's way better than many of the local town roads in my neck of the woods Mr. Gordon!
/ TODAYS SEAT TIME #13,939
The first picture looks unbelievably smooth !
What is “stay-mat” ?
I guess it is a local name here that applies to a road surface gravel mix that packs well - like "crusher run". What I get is from a local Pike plant. It is all crushed ledge and is a mix from 3/4" crushed rock down to stone dust with a little clay added.
With a little practice it tail gates out pretty well. On that stretch I ran down each side of the road with a load so there was double coverage in the center and thin on the edges. Makes it easy to crown.
Here is a 3 minute video I made several years ago .
gg
/ TODAYS SEAT TIME #13,940
2025 JMR Tree Boom Mini Skid Steer Attachment (A59228)
2025 JMR Tree Boom...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
2008 CAT 305C (A53317)
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
