1739e wiring?
/ 1739e wiring? #1
chidychi
Massey Ferguson 1739E
I'm trying to find a good place to tap switched power from.
I pulled off the "dash" and noticed that there are 2 connectors that are not connected. (both have orange with silver bands wires)
Also I've always wondered what the 2 wires near ROPES left rear is for? (If I short them it starts the engine...).
If you know a good place to tap switched power or have any idea what those connectors are for I would love to know.
Pics for reference:
Thanks!!
/ 1739e wiring? #2
No idea, but plug in a meter and turn on lights, see what happens. My old JD 870 had a pair of wires on rear fender. These were prewired rear lights.
/ 1739e wiring? #3
I found that the two wires on the ROPS show 12v when the ignition is off, no voltage when on.....
/ 1739e wiring? #4
Well thats weird……i wonder what would require voltage when ignition is off! It would drain the battery
/ 1739e wiring?
The weirdest part is that if you jumper them together it starts the tractor.....
/ 1739e wiring? #6
Personally I just taped 12 volts at battery terminal, used inline fuse between battery and switch and from switch to whatever required power.... To much work trying to decipher wiring diagram in manual and adapting to existing stuff (opening loom and such)...
/ 1739e wiring? #7
12v measured from one wire to the other, or each individually to ground?
Makes a difference
/ 1739e wiring?
That's what I ended up doing. Gave it it's own little rocker switch.
/ 1739e wiring?
Makes a difference
One of the 2 will be 12v to ground. The wires are acting like a switch. Connect them and the tractor tries to start. But why? why bypass the key?
The guy I bought it from only use it for the bucket on the FEL. Never used the 3pt. The PTO was still covered and factory greased..... so he didn't use/request those wires.
/ 1739e wiring? #10
Without seeing the schematic, I can only guess what’s going on , and that’s not really good troubleshooting.
Why are you connecting those 2 wires together? I would get a wiring schematic before you go further.
A lot of modern vehicle electronics use supplied +12v with switched negative for electronic circuits, instead of switched +, so you could inadvertently be connecting two different switching schemes.
May not be so with your tractor, but better to get a wiring diagram and know for sure.
/ 1739e wiring? #11
My Massy 1540 owners manual includes electrical schematics. Is it not included in the 1739e manual?
/ 1739e wiring? #12
Makes a difference
I don't recall, I investigated this sometime back, couldn't figure out what it could be used for and haven't messed with it since.
/ 1739e wiring? #13
Did a bit more investigation on the two wires behind the seat, figured it out, I think. According to the owners manual there are two 15 Amp fuses in the fuse block, one is for a work light the other is labeled outlet. Checking with a multimeter, one has power all the time the other only when the ignition key is on. I don't know which is worklight and which is outlet.
The owners manual is very minimalist, lots of pages of safety warnings,(don't attach implements with the PTO engaged, etc) not very much of the really useful stuff.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A64279)
2013 CATERPILLAR...
JOHN DEERE 6125M TRACTOR (A64280)
JOHN DEERE 6125M...
Mini Skid Steer (A60352)
Mini Skid Steer...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
