L5740 or some tractor
/ L5740 or some tractor #81
PS -- The mower / bush hog shown in your picture doesn't need hydraulics. If you are going to use a folding batwing, etc. you might need something. The blade in the other pic needs only one. Right???
Unless you plan to add the top and tilt equipment, you'll be fine with two sets.
/ L5740 or some tractor #82
I can probably do without "tilt" for my rotary, but the "top" is indispensable IMO. Being able to back to a bank (like when you're on top of a dam and mowing the side) and gradually lower the mower, etc.
"Tilt" is good for blades (though probably not in snow use?) & augers; for those who are using a tractor in part because of physical limitations and not purely for time efficiency, the more help the better.
/ L5740 or some tractor #84
I've also had to change the exhaust manifold gasket twice and it's out again now for the third time.
Just to update everyone on this issue, I ordered all the gaskets and got the tractor in the shop to find out it was not the manifold gasket. It was a small rubber tube about 2.5" long that connects a metal tube from a breather on top of the valve cover to another metal tube that goes to something else. I was able to find a replacement tube at a local parts store. None of the online Kubota sellers had this little tube in stock.
/ L5740 or some tractor #86
Don't have a clue about the newest T4-5 compliant tracrors, if the employ crankcase blowby consumption (back into the intake stream) or not. Do they? I don't know. I know that automotive related engines do (aka: EGR) but tractors, I have no idea about. Even my old 1997 7.3 diesel had it, but I removed it and added a 'road draft tube'. The only reason I did that was because When Navistar built the engine, they introduced the blowby vapor in front of the turbocharger intake stream and the introduction of blowby vapor in front of the turbo can and will cause the impeller wheel in the turbo to carbon up. Eliminating that vapor eliminates the potential carbon issue, consequently, I now have a road draft tube. Was easy to do as the engine has the vapor seperator on the drivers side valve cover so adding the appropriate venting was very easy and straightforward.
Always been my philosophy that the 'less junk in the trunk' equals less junk in the combustion chamber.
/ L5740 or some tractor #87
Another update. I went pick up the tractor, and when I got home, I could still hear the sound of a busted gasket. More investigation revealed that the exhaust manifold gasket is indeed still busted. I loaded it back up and returned it to the shop for them to replace the gasket. I did have to order another gasket that will also need to be replaced. I should get that by Wednesday.
Used tractors are showing up near us and a JD4320 just did priced at 18K.
2010 JOHN DEERE 4320 45 hp deere diesel HYDROSTATIC TRANSMISSION 4wd factory cab heat air conditioning work lights wipers mirrors 1 set rear hydraulic s mid pto 400x loader 73 inch QTACH BUCKET.
I asked the owner and it has 3700 hours.
The Kubota L5740 has had just one offer at $7000.. I told the fellow who's selling it we are still interested. Might offer them 39,000
/ L5740 or some tractor #92
Tell him you'll quadruple that offer and see what he says. You will still be getting a great deal.
Another JD snowing up one hour drive away. Its a rea rblower he has.
John Deere 4052R tractor package deal
$50,500
Details​
  • Condition
    Used - like new
For sale is 2020 John Deere 4052R 4x4 with only 593 hours. Stored indoors and kept in like new condition inside and out. Has had a very easy life mowing grass and moving snow. This tractor is loaded with about every accessories that you can add to it. It's up to date on all maintenance. Runs and drives and functions like new. No disappointments
593 hours52hp Yanmar diesel.
No Def crap.
MFWD/4X4.440r loader
Full cab with heat and A/C suspension seat Radio 12v plug-ins 2 rear reamote hydraulics LED work lights front and back Grille guard Front and rear windshield wipersOEM mirrorsThings
I've added 3rd function on loader for plow, grapple ectChanged loader carrier to skid steer quick attach.
Comes with deere hook and pin carriers tooDeere quick hitch/matchLED lights in everything, headlight, work lights ectRam phone holderDeere fender flares Deere oem 6" steele wheel spacersStudded all 4 tires for winter traction.
Easily removable.Rear tires are loaded with ballast/rim guardJohn deere OEM rear top and tilt cylindersTractor is being sold with these attachments listed.
All are in very good shape and work like new Deere 72c bucketVirnig 48" pallet forksMinnesota equipment 8' cross draw snow plowJohn deere/ frontier 1280 84" snow blower. Very heavy duty. Hydraulic chute rotation and flap.
Only interested in selling as a package. If bought brand new today this set-up would cost almost 100k. No trades. No low ball offers. No delivery.$50,500 whole package
/ L5740 or some tractor #94
$50,500
Details​
  • Condition
    Used - like new
No Def crap.
Only interested in selling as a package. If bought brand new today this set-up would cost almost 100k. No trades. No low ball offers. No delivery.$50,500 whole packageView attachment 3551261
View attachment 3551263View attachment 3551264View attachment 3551265
Nice looking package there! I didn't think you got Def until 75HP but it will certainly have DPF and still an emissions tractor (not that it matters to you). The Hydraulics on the rear and the 3rd function are very nice features to have. I may like that pre-emissions Kubota a little better though.
His "no def" statement was interesting.
4052r john deere I seen today. Looked new and asking 50 for everything, plus lots of items I needed were included.
/ L5740 or some tractor #98
That seems to be a much better deal than the Kubota.
Ya, 4 years old and like new. All the hydraulic connections we need. HD hydraulic snowplow included and rear facing blower. (forward would be so, so much better) Loader was switched to use standard attachments.
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
2014 PUMA  END DUMP TRAILER (A65643)
2014 PUMA END...
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
(1) 20 Yard Roll Off Dumpster and (1) 40 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
