shooterdon
Super Member
- Joined
- Nov 24, 2012
- Messages
- 5,528
- Tractor
- 2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
When I traded my 24 HP JD 855 i came close to getting the 35 HP LS 3100 series machine. At the time, I was in my late 60's and knew this would be my last tractor. For a few thousand more I decided to go with the bigger 4100 series and got the 40 HP model. In my case, I wanted a SSQA. more tractor lift capacity and a cab. The only thing I need PTO power for is snow blowing so my needs are different than yours.Don,
About a year ago I was talking to some folks here about the tractor after I had just purchased it and commented on what others thought were important to their choice in buying tractors.
A gentleman chimed in that he had purchased a 40hp unit that he used from time to time on his property for minor stuff... very minor.
Hearing that was unsettling for me. After all, I was - for the previous 2 years, all about studying how I would best fulfill everything that I could possibly use the tractor for and making determinations to skip this or add that based on what I was learning about as a newbie never owning anything like this ... a lot of that came from right here.
But this gentleman's response after I questioned the fact that he had spent so much money on something that he used so very little. Because that was what I had been working on in my head for the last 2 years...this Gentleman, so very wise and obviously much more a gentleman than I replied:
"Don, when you get to be a certain age, its not the cost. Its not how much you use it, maybe its not the color or the HP... but maybe it's having it when you want it, to do or not do whatever it is you want ... Life is short, being happy is imperative."
Now those may not be the exact words, but that's exactly what I gained from that short but wise conversation.
That concept my friend will never leave my side, and it came from this forum... awesome!!!
The point of my original post is trading for another 5 HP does not make a lot of sense to me. I do not believe adding 5 HP is a game changer, but I could be wrong. If I was not happy with what I have (as you are), I would size the tractor for what it needs to do and add a bit more to that specification. In my case, 40 HP engine (34 PTO HP), if i wanted more HP for the blower, I would go with the 55 HP engine with 47 PTO HP. Buy once cry once.
Now, to be honest, my HP is at the low end of what I need but I deal with it. First pass I go a bit slower when we get a heavy dump of snow. On subsequent passes I can keep going slow or take a 2/3 swath. If we were going to get 24" of snow, I would not wait for it to stop snowing and attack it all at one go. Not a big deal for me to go out 3 times during a once in a decade event to deal with a blizzard.
Grass is even easier to deal with, unless you are gone for weeks...months?? Take partial cuts or do it more frequently and reduce the load on the brush hog.
Just checked your specs and it seems a 60" BH would be another option. A good one is less than $2000 and you could use it when the grass is out of control. Same as a 17% increase in power. If you have a lot of grass to cut, you can keep your 72" for normal use. A lot less money than trading your Kubota unless you need a bigger machine of other uses.
60 Inch XTreme Duty Rotary Brush Cutter
The 60 Inch XTreme Duty Rotary Brush Cutter with 45 HP Gearbox and shear bolt PTO shaft, 60' cut, 66' wide, standard front and rear shielding, Free Shipping
www.everythingattachments.com
