Greenworks saw
/ Greenworks saw #1
metalbender
Sask, Canada
Massey 1742
My son was doing some serious cutting with the Greenworks brushless 40 volt saw along with the pole saw.
/ Greenworks saw #2
Looks like he's been busy.
Wife bought a GW mower and string trimmer about 5 years ago. It was to maintain a 2nd house (she was working remotely). It works OK.
I hate messing with small engines. I have an Echo 58v saw. Took down and bucked a 25 year old ash tree with it. Only problems are a tendency to throw the chain and they changed to 56v, so its an orphan. We are switching slowly over to DeWalt because of the wide tool options and reduced likelihood of being orphaned.
/ Greenworks saw #3
I have the 80v saw... It's awful heavy and the battery doesn't last very long. I don't think I've used it since the week I bought it. My gasser is just lighter and runs longer.
I'd definitely not recommend the 80V
/ Greenworks saw #4
I was tempted on the 80V “Hog” saw, the thing has a battery about the size of a car battery. The tests done with it looked amazing on the first cut, but it was real heavy and it lacked stamina.
I'd be all in on one when they finally get the weight down.
/ Greenworks saw #5
The batteries, if you want run time, are terribly heavy. The gasser is hard to beat
/ Greenworks saw #6
I have the 60 volt 20 inch bar and it is heavy also but it is very good at cutting larger trees and with the 8 ah battery it will cut a lot of wood , I use it for cutting about 5 cord of firewood and I have extra batteries so it will outlast me
/ Greenworks saw #7
I have a hard time believing that a truck charger, charging those huge batteries would run your vehicle battery down pretty bad.
I had DeWalt 60v battery saw and tried running it all day rotating 3 separate batteries, and I was barely able to get my truck started, even with dual batteries.
20' Bi-Parting Gate (Tree) (A62183)
20' Bi-Parting...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63118)
Dual Tailwheel...
John Deere 6330 (A62180)
John Deere 6330...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63118)
2017 Ford E-Series...
Giyi Tree Puller (A62183)
Giyi Tree Puller...
John Deere 50 (A60462)
