L5740 or some tractor
/ L5740 or some tractor #61
So if we get this tractor, it needs a grapple and the hydraulic lines to the front added to operated it. Plus have the front axle grease changed and those suspect bearings tested. With only one hydraulic circuit to the rear, does another need to be added? Also watching for a 4 series JD but many of those don't have a belly pto added.
It depends on what you want to do with rear hydraulics, but one set is pretty limiting. Most people at least want to have hydraulic top link and hitch tilt.
/ L5740 or some tractor #62
I’ve never had top-and-tilt or a quick-hitch. Guess I’m old fashioned and backward. But if you plan to switch to a rear snowblower, you’ll want at least one rear remote for chute rotation.
As jyoutz said above, it depends on what you plan to do with it. Define that and you can determine minimum needs and options.
/ L5740 or some tractor #63
He has me on ignore too...
Nice. In reality, I put Hay Dude on ignore (but took him off anyway) because every comment he made countering my posts were adverserial and condescending but I figure if I don't want to read his drivel (it's not all drivel btw), I don't read it.
For some reason I put you on ignore as well. Cannot remember why but when my pea brain realized you are on the other forum that I'm on as well and you leave constructive comments on there (sometimes interspersed with cynicism), plus you have that 090 I'm still contemplating on buying because 2 is better than the one I already own (mine is an 090G), I put 2 and 2 together and came up with 4 wich is hard at my age... anyway so I took you off the ignore feature on here. I like the other forum simply because it has a political section whereas this one don't.
In fact I removed everyone from ignore. easier for me to not use it and miss any good info because of my vanity. As a rule, I don't collect chainsaws nor do I modify them, well I did add the oiled foam air filter and offset crank key to my CS 590 Echo and opened up the muffler a bit as well and removed the miserable limiter caps. While I don't ever demean anyone over there because that is immature as well, the oiled foam air filter on the 590 is a royal PITA, not only to oil, but it gets everywhere under the shroud. Red Beard posts on there so I never say anything disparaging about his stuff. I don't buy into negativity, especially now that I'm a senior citizen.
I look at the ignore feature on this forum as a sign of immaturity and vanity, neither of which I have anymore.
Not sure if I should have posted this, but I did anyway. It's Arly's loss, not mine. I can keep on, keeping on, however, I want to take in as much as I can before my time in the sun is up...
/ L5740 or some tractor #64
Some people lack impulse control and need a nanny device like the ignore function to sleep well at night.
/ L5740 or some tractor #65
I used a hay bale grapple for a few years by running hoses from a rear remote. It was a real upgrade when I added a 3rd function. Really nice not to use the remote levers to actuate the grab hooks. Being able to keep your hand on the joystick when actuating a grapple makes it much easier to operate.
On my M's I actually have 3 in cab levers that operate the 3 remotes plus the topmost remote has flow control. I use the closest remote lever (top set) to actuate the '3rd function' if you want to call it that on the FEL, remember both of mine are a lot older than 'modern' units as well. Both are pre 4 100% mechaincal as in no electronics plus they fit my requirements 100% and are long time paid for... You have me curious as to the cost of adding remotes and /or a dedicated 3rd function and I'm not at the dealership this week but will be next week so I can peruse the dealer only Kubota website and get an idea of the cost, which, I'm confident won't be a cheap date. Kubota like JD has become extremelt 'proud' of their OEM parts but then it's that way everywhere today.
I looked at a dedicated grapple, tined bucket bit I have more than enough stuff sitting here that I don't use everyday and so I wanted a grapple but I wanted the ability to remove it as well which is why I went with the Green grapple. Besodes, having 3 buckets with 2 tractors, I always have one bucket sitting in the grass not being used anyway.
Talk about a complicated procedure, using my 3 point swing style stump grinder is complex in the least. I have to run the tractor in creep gear 1, control the swing with one remote lever and the up and down of the head with another lever and pick up the entire stump grinder unit every time I need to move the cutter wheel when grinding big stumps. That was a learning experience. It would have been better with a hydrostat but mine are both geared hydraulic shuttle units. I will say that last night a ground a huge oak stump and even my wife was amazed at the rate it ate it up. Putting 90 pto horses into the stumper really makes it work hard. I lacked enough swing to make it a one pass grind so I had to basically grind 3/4ths of it and reposition the tractor to finish it. I have a huge pile of oak chips in the side yard now.
/ L5740 or some tractor #66
I ordered the WRLong 3rd function for mine. It fit great and works great. It was around $800. Looked it up and it’s pushing $1000 now.
Two kubota rear remotes on mine were about $1100 but that’s been 10 years or so. All OEM so controls fit the console.
Both of these were parts only since I installed them. Add shop time to pay for the installation if needed.
Thank you. that was exactly what I wanted to know.
Would you do a 1/2 of a mile drive looking backwards? 😆
/ L5740 or some tractor #69
When I purchased my M9's new I spec'd them both with 3 sets of remotes plus flow control, cast steel centers and on the cab model, the 'deluxe' cab with aircon. rear wiper, front wiper and all the goodies. When I bought the second one, I forgot to order the creep gears but I did order both of them with the 2 speed 540-1000 rpm pto's. Only reason why I own 2 is the hay tools I use are pretty heavy and complex to hitch up so the cab tractor is set up for the computerized round bailer and the other open station runs everything else. I contemplated buying a lesser model but it's nice the way it is. Same filters, same sized tires, samr fuel capacity, basically the same but one has no cab. The older I get and I'm ancient, the less I like hitching and unhitching implements. Been told by the lead wrench at the dealership that the VTE engines I have are the best, longest lasting engines Kubota ever built ay over 5000 hours on each of them with no mechanical issues what so ever, they will far outlast me. I've replaced tires, and some bulbs and filled the washer tank a few times and of course changed the engine oil and trans oil but I've never had a mechanical issue with either one plus in today's EPA mandated market, they both hold their value as in the owner of the dealership told me if I sold either today, I'd probably equal what I paid for them, way back when. I'll leave all of it to my wife and she can off everything, it's all paid for, and take a nice long vacation to the Bahama's or whatever...😂
/ L5740 or some tractor #70
Well, I plow mainly. Only reverse when drifts are too deep. Much faster to plow.
And I can kinda get sideways in the seat and use my left foot on the hydro. Coffee cup is right there on the right. You’ll really like your warm cab come snow time.
Snow is big business here. We'd need to get a truck with a plow for light days, then blow on heavy or to get the sides that are built up removed. We have seen 48" in 48 hours.
/ L5740 or some tractor #72
Why does he need the ati QA? The Kubota factory one on it should work just fine.
My mistake - I read it didn't have SSQA - but after looking at the other pictures it does, All he needs is the 3rd Function and the rear remotes. A lot simpler and less $.
/ L5740 or some tractor #74
This is my opinion Arly so take it for what it’s worth.
I wish I had a grapple but get by with my forks. You can try and get by with the forks and add a grapple later. They are pricey is why I bring it up, if you have it in your budget I’d get it now then.
Rear remotes? I don’t have any and have never wished for them. I completely understand there use but for example I put a rear blade on and set it up and use it as is. Look at how you would use rear implements and decide if you need them or not.
I’m not trying to cheap you out on your future rig I just don’t want you to add stuff you might or might not need. It’s easy for other people to spend your money.
/ L5740 or some tractor #75
If you've got the money to make it work, get the remotes and 3rd function. You'll never regret a dedicated grapple.
/ L5740 or some tractor #77
Fair statement, it's only money after all. If it's only money, then why not buy new instead?
Well to be fair, the prices between new and used Deere/Kubota equipment could add a lot of accessories. The MSRP of these machines is painful!
/ L5740 or some tractor #78
The primary reason why I purchased the Green weld on bucket grapple and the Vevor add on debris forks is adaptability with existing equipment. I already have enough 'stuff' and adding a dedictaed grapple would just add to the stuff inventory.
I can remove both the clamp on debris forks as well as the Green grapple from the bucket (I used the light duty material bucket I own as the base for the Green grapple). I can remove both the grapple attachment as well as the forks in a couple minutes if I require the bucket for other tasks and both my M9's are SSQA 2 pin attach to begin with and I already own a blower (72" lucknow rear mount blower as well as my 10 foot power angle snow plow that is SSQA in the first place, not that I like plowing snow, because I don't. Cost wise, the Green grapple as well as the add on forks were a ton less expensive than a dedicated grapple to begin with other than welding on the hrapple base which was a non issue for me. Remeber, I own and operate a welding and fabrication, short run machine shop so I have the tools necessary for that modification.
I'm all about multi use implements and easy interchangeablilty and the Green grapple as well as the Vevor clamp on debris forks meet that requirement for me. There we a ton of negative reviews on Amascon concerning the Vevor clamp on DEBRIS forks but it was easy for me to surmise that people were buying them and useing them to mover heavy things like boulders and bending them. Not designed or built for that. They are built for DEBRIS removal only. I aso own a set of SSQA heavy duty pallet and skid forks rated for 6,000 pound capacity and the Vevor debris forks aren't for that at all.
I used the light duty material bucket (remember I own a HD excavation bucket, actually 2 of them as well) and all of them are SSQA. I would never add the Green grapple to either round back excavation buckets anyway. The added weight of the Green grapple and the Vevor debtis forks is inconsequential for me as my lift capacity on either tractor I own, far exceeds what I'd ever pick up anyway.
I could not see buying an additional dedicated grapple attachment so I went the add on grapple route I already have enough 'stuff' in the barn as it is. I also like the fact I can remove the Green grapple quickly if necessary as well as the clamp on forks and use the bucket for other tasks like what it was designed for, material (dirt) handling.
They certainly are not for everyone but for my use, they are an ideal addition as are the clamp on debris forks. If the Green grapple and debris forks were for everyone, then no manufactirer would build of see dedicated grapples or heavy duty pallet / skind forks. In fact, clamp on forks on ANY light duty (single sheet bottom) material bucket and using them to move heavy objects or use them for prying something (like a stump loose from the ground) will impart a 'smile' in the bottom of the bucket and render it useless for dirt levelling tasks. I've repaired a lot of smiling, light duty buckets over the years where owners did just that and bent the lower sheet and why I own the HD double bottom sheet round back excavation bucket as well.
When you bend the lower sheet on any material bucket, you also pull in the side sheets and they most times require cutting them away to level the bottom sheet and then rewelding the side sheets again and none of that is a quick or cheap fix.
We have been clearing trails for many, many years but at the point, I have a wrist that no longer likes doing that. We have to switch to a tractor but we have used them on trails in the past. The rear hydraulics would be for a 3 point mower, or back blade. Front is for a grapple.
/ L5740 or some tractor #80
OK. Then add at least 2 sets of remotes on the rear. Way easier to add them at the same time than come back later and take everything apart to add another single.
If you can adjust top links and side link manually, you probably don't need any more than two. If you think you're going to want more, go for all three. I don't use anything behind that tractor that needs more than 2 remotes. Usually only need one.
I think we've beat this up enough.
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2025 DELCO T/A 24FT GOOSENECK TILT DECK TRAILER (A59914)
2025 DELCO T/A...
213085 (A64276)
213085 (A64276)
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
