Please explain this difference between diesel and gasoline engines
   / Please explain this difference between diesel and gasoline engines #181
I know a guy thats teaching his daughter the earth is flat!
I didn't believe it until my neighbor told me its true! :unsure:
willy
   / Please explain this difference between diesel and gasoline engines #182
Modern two strokes , and four cycle as well, are all about HARMONICS.
That is how today's engines can achieve over unity volumetric filling.
I can not think of a single instance of a "modern" sleeve valve engine.
A once in a lifetime era I suppose.
Gone the way of the dinosaurs.
eta
Does anyone know of an example of a sleeve valve compression ignition engine?
Willys Knight. Designed because of the lack of the metal needed for regular valves. But I don’t the sealing characteristics were sufficient for CI.
   / Please explain this difference between diesel and gasoline engines #183
willy
It is in small areas. Otherwise a spheroid.
   / Please explain this difference between diesel and gasoline engines #184
The earth, with all it's trenches deep and mountain ranges high, is a more perfect sphere than any man made object!
And let me tell you CSRIO in Australia put a lot of effort into doing better.
   / Please explain this difference between diesel and gasoline engines #185
No, not even close to the spherical accuracy of the common ball bearing.
   / Please explain this difference between diesel and gasoline engines #186
   / Please explain this difference between diesel and gasoline engines #187
Sorry, while the circumference of the earth about the equator is close to the circumference through the poles, it is only close.
Ball bearings are so precise their manufacturing technique was one of the most closely guarded secrets of WWII.
After the war when Japan was retooling and establishing their own metric interchangeability standards the sole exception was for ball bearings. They were allowed to purchase American tooling for ball bearing manufacture so they accepted SAE dimensions. Most Japanese cars and motorcycles used SAE sized ball and roller bearings the next 40 years.
   / Please explain this difference between diesel and gasoline engines #188
More perfect that a steel ball bearing? Wow.
   / Please explain this difference between diesel and gasoline engines #189
Most ball bearings are actually metric in size.
   / Please explain this difference between diesel and gasoline engines #191
Now they are but they were not always.
I was surprised to find my 1976 Honda MR175 had inch-sized main crank bearings. Cost much less from the local bearing supply store than from the Honda dealer.
   / Please explain this difference between diesel and gasoline engines #192
Did they happen to be "New Departure" brand?
12' CONTAINER (A52706)
2012 FORD F-350 XL SUPER DUTY CREW CAB SERVICE TRK (A60430)
2012 FORD F-350 XL...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
2017 John Deere 5090GN (A53317)
2017 John Deere...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
