Generic gasoline engine tuning question
/ Generic gasoline engine tuning question #21
You really do need a manual - the problem as you describe it could be everything from a stuck advance on the distributor to a governor out of adjustment to a carb issue.
What engine is in it and what carb? Lots of times there are crossovers with other tractor makes and often dealers will order parts for other makes for you rather than go the hundred miles.
According to what I've got, the engine make is Toyo-Kogyo (Mazda) model M471G The carburetor is by Nihon Kikakki, 18.6mm downdraft style. I haven't been able to find any cross-references for compatible parts.
/ Generic gasoline engine tuning question #23
Too much fuel is not as common as not enough as there are lots of things that can reduce fuel flow, not to many that can cause too much. But in this case it sounds like too much fuel (to air). First thing I'd check is to make sure the choke is fully open...
/ Generic gasoline engine tuning question #24
284,
Curious if you've made any progress on this?
Jim
/ Generic gasoline engine tuning question #25
From all this I can think of only a couple good possibilities:
1] You have a little puddle of water under the main jet that doesnt quite reach it at idle, but gets sucked up to it as soon as you throttle up.
2] Your distributor cap is bad - when cylinder pressure goes up it is harder to spark a plug and the spark will take erroneous routes. Hence the popping.
To check for #1, get the engine reving good and then slam on the choke. Assuming you have the regular type choke that acts by obstructing the intake, this will suck some of the water out and should improve things. [This will not work with an enrichener type "choke".] If it improves its dry gas additive time :).
To check for #2, clean the inside of your cap with alcohol and let dry thoroughly.
I dont think you have a significant rich condition or you would notice some black in the exhaust and smell the unburnt gas.
larry
I have made some minimal progress on this issue. I disassembled the carburetor and cleaned out the main and pilot jets, cleaned the float valve seat, and just generally sprayed the inside of the carburetor out. Everything looked clean and in good shape, and no gunk or varnish or anything came out.
I also discovered why, sometimes, there's a slight smell of gasoline when the tractor is running: The fuel pump diaphragm has dried out, and sometimes leaked a little fuel. However, after disassembling it to correct this, the gasket broke, so now it sprays a LOT of fuel. Since I'd rather not die in tractor fire, I ended up installing a low pressure electric fuel pump. On the positive side, the tractor now fires up almost instantly, since there's instantaneous fuel pressure to the carburetor. On the negative side, my tractor sounds like my '71 Nova drag car with a humming electric pump....:rolleyes:
I cleaned the points and checked in the distributor cap, everything looked very clean and in good shape. I *think* I've ordered a replacement set of points, condenser, and a new coil that should all work from NAPA; we will see. It still doesn't feel like an ignition problem.
In experimenting more, and comparing the symptoms to prior experience, it feels a lot like an engine does that doesn't get enough fuel from the accelerator pump when the throttle is opened. It feels fuel starved, I think, when the throttle is opened. I think the slightly sooty exhaust and black plugs are from extended idle-rpm operation, and may be misleading as the actual problem (Since it doesn't like to run at rpm above idle very much, until it has been slowly worked up to it over 30 seconds or so.)
/ Generic gasoline engine tuning question #27
I'm not familiar with the exact engine that you have. Does it have an adjustable distributor where you might increase the timing.
Did you think to check the float level. With the carb inverted, it should be pretty near parallel to the top of the carb. I always shake the float while I have it off to insure that it isn't leaking.
If it fires off instantly, then the points are probably good. I would look closer at fuel and timing/ advance.
Jim
/ Generic gasoline engine tuning question #28
Once upon a time I had a set of new points that we installed at the same time we put in a cam chain. The engine idled fine but did crazy stuff if you tried to rev it. After disassembly to double check cam timing we finally put a timing light on it and found the spark going intermittent when reved. Put in the old points and it was fine! :confused::confused2:. With the popping his problem definitely could be spark related.
larry
/ Generic gasoline engine tuning question #29
It absolutely could be spark related and the points could be bad. I never say never and I never say always when dealing with this sort of problem. My statement regarding the points was a best guess based upon past experience with ignition systems from the 50's, 60, and 70's. I am dealing with my perception of probabilities. I personally have not seen a properly installed and tested set of points behave in this manner. I have seen poor high rpm performance resulting from a weak spring but, not at low to mid rpm.
Sorry if I misled anyone.
The points that arrived do not fit, but the guy at Napa assures me he will get the right ones. It still "feels" like a fueling issue, running too lean, but the sooty black plugs imply otherwise, and sometimes it stutters briefly when at higher rpm, which very well could be an ignition issue. When quickly stabbing the throttle, the stumbling is improved by activating the choke. That appears to be improved and a little different after putting in an electric fuel pump. I'm still at a loss as to what else to try. Thanks again for all the tips and ideas.
/ Generic gasoline engine tuning question #31
If the stumble is improved by choke then it's definately a lean condition. Have you checked for vaccume leaks? Also make sure the float bowl is vented to atmospheric pressure or the venturi effect won't be on your side:) Typically there will be a hole in the air filter side of the carb which leads to the float bowl.
Also be careful with that electric fuel pump, you may need an adjustable fuel pressure regulator ($30 bucks at most auto parts stores) to keep fuel from pushing past the needle and seat.
Carpenter, I put a low pressure adjustable regulator onto the already low-pressure pump. So, thanks; I have it covered.
I should have been more clear, as well: pulling the choke only helps after initially opening the throttle, basically to cut off the air supply and richen the mixture for a short period. After a short time (less than 2 seconds) having the choke on makes it run worse and/or die. So, it doesn't run better with the choke on (In fact, it won't start or run if I use the choke at all) except for very briefly if I open the throttle to wide openings.
I have neglected to check the float bowl vents and their affiliated vent lines. I'm going to do that right now. Thanks.
/ Generic gasoline engine tuning question #33
Hello! Had just bought a 284 and had the same problem. replaced with new plugs and wires. Still stumbled. Firing order is 1,3,4,2. Install from #1 on distributor 1,3,4,2 it may solve the problem.
Hi, I have a gas IH 284 that really lacks power. When it attempts to pull a load (even starting itself out with no implement or trailer) the engine bogs, stumbles, and runs roughly. With no load, it runs smoothly, but it is difficult to throttle up: opening the throttle, even with no load, makes it stumble.
I have replaced the spark plugs and fuel filter. The spark plugs were sooty and dark black (including the new ones after less than an hour of use), and the fuel filter was free-flowing. I have replaced the air filter, and even tried it briefly without the air filter, all for no change.
I'm sure these symptoms mean something to someone with more knowledge than me, but I'm out of ideas. What should I try next? Thanks in advance.
John Deere 4044M (A60462)
John Deere 4044M...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2021 BOBCAT T76 R-SERIES SKID STEER (A63290)
2021 BOBCAT T76...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
200 GALLON FRONT MNT POLY TANK & BRACKET (A63745)
200 GALLON FRONT...
Location (A63116)
Location (A63116)
