Push over trees with a small compact?
/ Push over trees with a small compact? #1
oakhilltop
New Hampshire
Massey Ferguson 1E.25
I've seen some videos where people say that they use their compact or scut tractor to push over trees. The base of trees can hop up as they fall, so I'm wondering about peoples experiences with doing this with a smaller tractor.
For an 8 or 10 inch diameter tree, maybe 60 feet or more tall,
Would it be safe to:
- notch the tree in the direction that I want it to fall
- start a back cut
- then use the front end loader to encourage the tree to fall in the desired direction
/ Push over trees with a small compact? #2
Not safe. Any loose limbs could fall on the operator. If the tractor isnt big enough, the tree could fall opposite the intended direction. You really dont have 100% control over the tree through the entire cutting process.
The safer option is to set a winch to another solid tree and maintain a pull through the entire process using a cable or bull rope long enough to get you out from under the tree.
That has been my opinion also. Trees can be very uncooperative. I've always parked the tractor a safe distance away, in case the tree decides to go in a different direction. I've been using a maasdam rope puller when needed.
  • Good Post
Reactions: fc1
/ Push over trees with a small compact? #4
Agreed. I don't even like the way I see many folks winching, putting pressure on the tree before the cut is done, as it can increase probabily of barber chair.
Arrange your line to prevent back fall, but don't start putting big tension on it until after the hinge is fully formed and cutter is out fo the way.
Preferred process for back-leaners:
  1. Use throwing bag, rock, or slingshot to throw a lightweight line as high into the tree as you can, looping it over a major branch.
  2. Use lightweight line to pull your heavier line up into place. There may be a medium line involved, if light line is not sufficient to pull heavy line.
  3. Tie bowline loop or other free-sliding knot in free end of heavy line (from ground), so it can be pulled up and cinched into crotch of tree.
  4. Tie bowline into far end of heavy line, and figure out what tree base you'll use for your pulling. You really want more than 1:1 scope, preferrably 2:1 to 3:1 in run:rise.
  5. Attach strap to tree base that will be used for pulling, and attach winch to strap. Play out winch line and attach to your heavy pulling line.
  6. Tension only enough to lift rig (winch + line) off the ground.
  7. Make face cut.
  8. Start back cut. As tree tries to sit down and pinch bar, either drive in your wedges or have someone tighten winch just enough to prevent cut from closing, but not enough to put tension on tree.
  9. Finish back cut, get you and your saw out of the way, and then start cranking on the winch.
When you see trees barberchair, and basically explode while someone is in the middle of their back cut, there's a good chance a too-tight winch was involved.
Most of the time I put a line in a tree, it ends up being nothing but extra insurance that the tree doesn't fall backwards onto whatever I'm protecting, and I never end up having to even use the winch. You can do a lot with a few plastic wedges. But the point is, if you're going to use a winch, don't tighten it beyond the point of just holding the tree, until after the cutting is done.
/ Push over trees with a small compact? #5
Doubling the line by adding just one pulley really makes a huge difference in what can be pulled with a maadsam rope puller. They are very affordable. Much safer to use leverage pulling from higher up in the tree as winterdeere explained than trying to push a tree over from the trunk. So much weight and leverage in the tree working against you doing that.
/ Push over trees with a small compact? #6
Doubling the line by adding just one pulley really makes a huge difference...
Physics is phun! Another one folks might forget from their high school physics is that any pull applied to the middle of a tensioned line has basically infinite mechanical advantage when the line is straight, decreasing only according to how far you pull that line off center.
In other words, your 115 lb. wife might be able to pull over that 10,000 lb. back-leaner, if you just have her pull down on the middle of the tension line... assuming it's long enough to keep everyone safely out of the way. You can even throw another line over the tension line, so that you can run it up as far as you need, and then stand next to the tree you've just cut while pulling down on the tension line.
Why would anyone care about this? You'll realize the first time you've tightened the winch as far as it can go, and the tree is still in the air. :oops:
/ Push over trees with a small compact? #7
I tried that with cedar trees that I had chopped with a chain saw. I found pushing out most stumps without digging was difficult. I avoided full or even medium trees being pushed down prior to cutting them down.
/ Push over trees with a small compact? #9
On a healthy tree all the way up it's so so but still risky if it's dead it's a hard no no, it's just not worth the risk in my opinion too many things can go wrong.
/ Push over trees with a small compact? #10
Best thing I bought for my compact Deere 3038e was a remote control winch and hp module, now 51 hp. Recently cut a few trees, tractor well back with FEL down front tipped slightly in ground, brakes, chock, rear weight.
Cable up high just taking up slack, remote in pocket. I made notch low then back cut. As soon as I saw notch widen a bit I ran back...winch remote to pull. It worked great.
I only push over little trees, about 3" dia with FEL. Yesterday I did remove two stumps for neighbor, about 12" or so. I had backhoe on but used bucket. They were dead for years and we've had lots of rain so it was easy.
I used winch to help pull stumps into bucket.
/ Push over trees with a small compact? #11
It's funny you mention the winch. I have a nice 7500# winch with 75 feet of cable on my logging trailer, and never even thought of using it for pulling trees. I always use an old-skool come-along to the base or stump of another tree.
/ Push over trees with a small compact? #12
Winch with a rope longer than tree height. A little tension while notching, then complete cut while reeling it in.
/ Push over trees with a small compact? #19
Tractors aren’t the immovable anchor points some apparently think they are.
Even if they were, often the mains issue is while pushing on a tree with a machine the tree snap in half, then fall on itself or the cut hinge let go, the bottom kick out and the tree fall on the equipment.
/ Push over trees with a small compact? #20
Learn how to chainsaw fall and use wedges to control the path.
This is how I do at least 95% of my felling. But I can remember at least two in the last ten years that were leaning so far the wrong way, or had to be steered around another tree on their way to the ground, where I used a winch and line to pull it over after making both cuts to form the hinge.
2020 John Deere 6120M (A62180)
2020 John Deere...
19 gal Portable Sandblasting Cabinet (A66408)
19 gal Portable...
2) 30'  42" High Pipe Racks (A62679)
2) 30' 42" High...
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2018 John Deere 3025E (A64126)
2018 John Deere...
