R4 tires for the front of my JD 2520
/ R4 tires for the front of my JD 2520 #1
Dagoof
Idaho Falls, ID
John Deere 2520
I have a 2010 JD 2520 (before they became smaller). I do mostly mowing work, and truf tires are mostly okay, but the front tires are wimpy and I'd like to put the industrial tires on. Two question though:
1. Am I going to have a problem with tire sizes for the four wheel drive? I think there is a slight difference, so I'm worried about keeping the back truf tires on
2. Is there a decent place to buy tires and wheels? Anyone here have an extra pair after going to turfs?
/ R4 tires for the front of my JD 2520 #2
Can you put R4's on the same rims? Front turf's are 24x8.5-14, and front industrial (R4) are 23x8.5-12
Don't know what you mean by "wimpy" but do you find they are not adequate in "four wheel drive" when mowing ??
/ R4 tires for the front of my JD 2520 #3
No, the front rim sizes for turfs on 2520 are bigger than for R4 and I think the rears are smaller for turfs than R4.
So you're saying I'll have to buy a full set or tires and wheels?
/ R4 tires for the front of my JD 2520 #5
Yes, both front and rear wheels are different between R4 and R3 tires on the 2520.
/ R4 tires for the front of my JD 2520 #6
Below is from Tractor Data for a compact 2520 from yrs. 2005 to 2011.
John Deere 2520 Tires
Lawn/turf front24x8.5-14
Lawn/turf rear36x14.00-15
Industrial front23x8.5-12
Industrial rear14-17.5
/ R4 tires for the front of my JD 2520 #8
On my 4320, I ordered it with R4 industrial bar tires in 2006. I also ordered a front set of R3 turf tires and rims, at $200 each, at that time. To me the new rear turfs were to expensive/ like $900 each~.
At about 3 years in I found a set of used R3 turf tires and rims on the internet, ebay, for about $325 from memory. The seller
told me he had been trying to sell these several times on ebay with no takers. I thought it was a steal so I left work to go get them.
I put on the new front R3's and the used rear R3's for mowing in the summer time. I gave the used front turfs to my broth-in-law and he used the rims on his hay wagons.
Two years ago I purchased new ( seconds ) rear R3 turf tires, $600 each~. I have been switching tires, summer and winter for the last 15/16 years.
When I looked for a new set of turf tires and rims at that time, they were priced well over $2000.
If I were you I would start searching the internet for a set of tires. I know I looked for at least 4/5 months until I found the above.
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
pressure washer, and trailer (A56859)
pressure washer...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
