Satoh S470D Injector Return Line size
/ Satoh S470D Injector Return Line size #1
Steve777
Does anyone know the correct size rubber return line from the injectors back to the tank?
Could just measure the old ones, but they are quite swollen and not sure I'd get the right size.
Thanks.
/ Satoh S470D Injector Return Line size #2
If they're the ones I'm thinking of I just replaced mine with irrigation drip line parts. There's really no pressure on them. That tractor was a Mitsubishi D2350 if it makes a difference.
/ Satoh S470D Injector Return Line size #3
It’s going to be metric (mm) so either measure the connector or take it with u to the auto parts store..
/ Satoh S470D Injector Return Line size #4
Measuring the fitting is a good idea, but...make sure to use fuel line otherwise the fuel will deteriorate the line over time and tiny bits of rubber will wind up in you fuel.
Thanks. Looks like I will need to measure. Will probably get Viton fuel line, as it is more resistant to fuels and additives and might last longer.
1988 Ford 8210 (A60462)
1988 Ford 8210...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2018 MACK CXU (PINNACLE) (A60736)
2018 MACK CXU...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2018 CATERPILLAR 262D SKID STEER (A62129)
2018 CATERPILLAR...
2020 DRAGON ESP...
