Satoh S470D Injector Return Line size
   / Satoh S470D Injector Return Line size #1
Steve777
Does anyone know the correct size rubber return line from the injectors back to the tank?
Could just measure the old ones, but they are quite swollen and not sure I'd get the right size.
Thanks.
   / Satoh S470D Injector Return Line size #2
If they're the ones I'm thinking of I just replaced mine with irrigation drip line parts. There's really no pressure on them. That tractor was a Mitsubishi D2350 if it makes a difference.
   / Satoh S470D Injector Return Line size #3
It’s going to be metric (mm) so either measure the connector or take it with u to the auto parts store..
   / Satoh S470D Injector Return Line size #4
Measuring the fitting is a good idea, but...make sure to use fuel line otherwise the fuel will deteriorate the line over time and tiny bits of rubber will wind up in you fuel.
Thanks. Looks like I will need to measure. Will probably get Viton fuel line, as it is more resistant to fuels and additives and might last longer.
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53473)
2019 New Holland...
2005 Ford F-750 Crew Cab Heil 5 Yd Mason Dump Truck (A51691)
2005 Ford F-750...
Year: 2017 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 69158 Plate: Body Type: 2 (A53422)
Year: 2017 Make...
2003 Chevrolet Silverado 2500HD Ambulance (A51692)
2003 Chevrolet...
