Satoh S470D Injector Return Line size
   / Satoh S470D Injector Return Line size #1
Steve777
Does anyone know the correct size rubber return line from the injectors back to the tank?
Could just measure the old ones, but they are quite swollen and not sure I'd get the right size.
Thanks.
   / Satoh S470D Injector Return Line size #2
If they're the ones I'm thinking of I just replaced mine with irrigation drip line parts. There's really no pressure on them. That tractor was a Mitsubishi D2350 if it makes a difference.
   / Satoh S470D Injector Return Line size #3
It’s going to be metric (mm) so either measure the connector or take it with u to the auto parts store..
   / Satoh S470D Injector Return Line size #4
Measuring the fitting is a good idea, but...make sure to use fuel line otherwise the fuel will deteriorate the line over time and tiny bits of rubber will wind up in you fuel.
Thanks. Looks like I will need to measure. Will probably get Viton fuel line, as it is more resistant to fuels and additives and might last longer.
6 ft. Rotary Cutter (A53117)
6 ft. Rotary...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
LINDE WELDER (A53843)
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
Unused 2025 Electric Cart (A51694)
Unused 2025...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
