Repair questions for a 2007 Montana 5740C
   / Repair questions for a 2007 Montana 5740C #1
SteveMo
New Brunswick, Canada
2006 Montana 5740C
Hi, all:
Over the winter, the tractor has had a bit of a workout. I need some repairs, but unsure how to go about them.
1) The glow plugs indicator no longer lights when I turn the key to the pre-ignition setting. Is there a thermostat for these so that the glow plugs don't work when the ambient air is warm? I checked the two fuse boxes that I could find and neither one indicated that they were for the glow plugs. I would like to try to fix this myself if anyone can suggest anything that I could try?
2) I can't remove one half of the PTO shaft from the snow blower that was attached to the tractor. There is a quick release coupler there but I have tried everything to get it off. It's clean and I tried some WD40 on it. Perhaps the collar isn't able to be pushed in far enough? I don't want to damage it from being forceful. Anyone with a suggestion would be helpful.
Sorry for the Newbie questions. The only manual that I ever found is in Chinese.
Thank you!
   / Repair questions for a 2007 Montana 5740C #2
I’ve had to pry a little bit to get a pto shaft off sometimes but most of the time they slide off.
Montana went out of business a few years ago but I think they were made by LS if that’s any help.
   / Repair questions for a 2007 Montana 5740C #3
Glow plug system is controlled by a relay located on the firewall on the rh side of engine. Try using penetrating oil rather than WD 40 on the PTO shaft collar. Don't be afraid of giving it a good soaking and leave overnight. LS dealer can help with part number for glow plug controller relay.
   / Repair questions for a 2007 Montana 5740C #4
   / Repair questions for a 2007 Montana 5740C #6
Have you tried to release it and pushed forward then a
quick yank back all the while holding the release ?
willy
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Bobcat S740 (A57148)
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
JOHN DEERE 470G LC EXCAVATOR (A60429)
JOHN DEERE 470G LC...
