Repair questions for a 2007 Montana 5740C
   / Repair questions for a 2007 Montana 5740C #1
SteveMo
New Brunswick, Canada
2006 Montana 5740C
Hi, all:
Over the winter, the tractor has had a bit of a workout. I need some repairs, but unsure how to go about them.
1) The glow plugs indicator no longer lights when I turn the key to the pre-ignition setting. Is there a thermostat for these so that the glow plugs don't work when the ambient air is warm? I checked the two fuse boxes that I could find and neither one indicated that they were for the glow plugs. I would like to try to fix this myself if anyone can suggest anything that I could try?
2) I can't remove one half of the PTO shaft from the snow blower that was attached to the tractor. There is a quick release coupler there but I have tried everything to get it off. It's clean and I tried some WD40 on it. Perhaps the collar isn't able to be pushed in far enough? I don't want to damage it from being forceful. Anyone with a suggestion would be helpful.
Sorry for the Newbie questions. The only manual that I ever found is in Chinese.
Thank you!
   / Repair questions for a 2007 Montana 5740C #2
I’ve had to pry a little bit to get a pto shaft off sometimes but most of the time they slide off.
Montana went out of business a few years ago but I think they were made by LS if that’s any help.
   / Repair questions for a 2007 Montana 5740C #3
Glow plug system is controlled by a relay located on the firewall on the rh side of engine. Try using penetrating oil rather than WD 40 on the PTO shaft collar. Don't be afraid of giving it a good soaking and leave overnight. LS dealer can help with part number for glow plug controller relay.
   / Repair questions for a 2007 Montana 5740C #4
   / Repair questions for a 2007 Montana 5740C #6
Have you tried to release it and pushed forward then a
quick yank back all the while holding the release ?
willy
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
2024 JOHN DEERE 8RX310 LOT IDENTIFIER 73 (A53084)
2024 JOHN DEERE...
2002 CRESCENT 102" X 53' STEP DECK TRAILER (A51247)
2002 CRESCENT 102"...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
