LS XR4145HC starting problem....
/ LS XR4145HC starting problem.... #21
Mine used to make the "duck squawking" sound sometimes after shutting down. I seem to remember reading somewhere this noise can be caused by the turbo not cooling down sufficiently. I am now very strict about idling at 800 RPM for at least 2 minutes (if not more on hotter days) before shutting down. When I do that, no squawk.
I will replace those two items I mentioned above and let you guys know. I very much appreciate all the suggestions from this group.
If it is cranking but not starting then your issue is that it is probably not getting any fuel.
Is your fuel solenoid being energized?
There are two way to shut a diesel engine off, stop the air from entering the engine or stop the fuel.
I would guess you are not getting power to keep the fuel solenoid energized (open). Possibly it's relay is not working or a safety switch (brake, range lever, PTO, seat,.....) which is typically in the circuit is preventing it from being energized.
Where is this fuel solenoid located or the relay?
/ LS XR4145HC starting problem.... #24
Sorry I'm not that familiar with your tractor to direct you their specific locations. You may be able to trace the fuel system to find the solenoid, most likely its close to the injection pump or at least that's where it is located on tractors that I'm familiar with.
Do you have a operators manual as it may give you a general overview?
After replacing the battery, both battery cables and the ignition switch I still get nothing when I turn the key to run. The dash board energizes, the glow plug heats up and the light goes out but when I turn the key the rest of the way to turn over the engine nothing happens. I can manually jump the S terminal to the hot wire on the starter solenoid and the engine will turn over just fine, but it won't fire up. Any ideas?
/ LS XR4145HC starting problem.... #26
Have you been able to make any progress ? Are you sure there’s fuel in the tank ?
The problem is that I can't get the starter to engage without jumping the S pin on the starter to the hot post, the key won't turn over the engine. Yes it has fuel so that is not the problem. Once I get the engine to turnover normally from the ignition switch I think it will start.
Update: I have confirmed that I'm not getting any voltage from the signal wire at the started to tell the starter to operate. I'm pouring over the wiring schematic and have decided that I need to locate the Starter motor(mini) whatever the hell that is?
The signal wire is black with yellow strip so I'm pretty confident this is the wire I highlighted below. I don't know what this Starer motor (mini) is, it looks like a relay but everywhere else in the schematics where they show a relay, they also call it a relay. I want to locate this item and see if I can replace it working my way up the wiring harness.
/ LS XR4145HC starting problem.... #29
That is the starter relay. When the key switch is held to the start position you should have 12 across pins 4 and 2. If not the problem will be a ground or the Key switch. If you get power there you should have power across 4 and 5 with key in start position. If not then you should see power with the key in the run position across 4 and 1. If you have power across 4 and 1 but not 4 and 5 then the relay is bad.
/ LS XR4145HC starting problem.... #30
I would have thought there would be some "safety switches" in the circuit for the starter relay to be energized like the tractor being in neutral, the PTO not engaged, parking brake on, seat switch being made like someone is sitting it......
Those are the first things I checked, all is good.
Theclimer, when you say verify, if you mean simply by making sure the PTO is not engaged or making sure I'm sitting in the seat etc., yes we have done that. Are you talking about a different way to test them?
/ LS XR4145HC starting problem.... #34
Making sure the PTO was not engaged or that someone was in the seat was the first thing you needed to confirm. But without using a meter to verify the switch is being made or bypassing these safety's you have not eliminated them as being the problem.
In addition to the ones I circled I'd have to believe you also have a switch to determine if the tractor is in neutral and that the main PTO is not engaged, I did not look further at the electrical schematics for these.
PTO is not engaged and tractor normally starts in any gear, I think it might have something to do with it being an HST model.
/ LS XR4145HC starting problem.... #36
I would Try disconnecting the battery and working all the switches that could possibly cause it not to start then reconnect the battery to see if anything changes.
/ LS XR4145HC starting problem.... #37
I rerouted a new positive cable from the battery to the starter solenoid. It went bad somewhere in the odd “L” off the post. Didn’t remove the factory cable just added a new one and bingo problem solved and it’s been great
John Deere 4455 (A64119)
John Deere 4455...
40' New Container (A62679)
40' New Container...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
2013 Bush Hog 296 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
2013 Bush Hog 296...
JOHN DEERE 6105D TRACTOR (A64280)
JOHN DEERE 6105D...
