Dry asphalt seal
/ Dry asphalt seal #1
Lakeside57
Longview, Texas
John Deere 1520 Diesel
Had dry asphalt laid in part of driveway. Being a loose asphalt, is there a way to seal it by spraying. If I pour the liquid sealer and use a push broom it will move the loose top layer. Is there a spray method? Thanks
/ Dry asphalt seal
It’s asphalt that basically has no tar or bonding. The more traffic the more it packs down. Not sure the correct name.
/ Dry asphalt seal #4
Sounds like millings to me. If you pour sealer on it, it will absorb to below the surface. Unless it's compacted well above 100%. And it still won't do what I'm thinking you want it to do. And the Texas sun will wick out pockets of it and make quite the mess.
Just my opinion.
/ Dry asphalt seal #6
My neighbor put quite a bit of that down. If it's rolled and compacted really well hot summer days should cause the residual tar or whatever they used to melt somewhat and bind it again though not as nice as original.
/ Dry asphalt seal #7
I would look into buying a 50 gal barrel (or 5 gal bucket of Special MS, medium set, asphalt emulsion, often used to prime). What you are describing is a prime coat, often with sand (or if we get fancy, granite screenings) spread on top.
I think the price is around $6/gal. It's applied warm, to mildy hot, but you could pull the nozzles out of a sacrificial pump sprayer. You also can dilute it with additional water.
/ Dry asphalt seal #8
So, on RAP (millings) "resetting" in summer... ahhh, maybe, but not likely. Most roadway milling is only asphalt with very little remaining AC content (asphaltic cement, the Black sticky stuff that holds it together), asphalt is ran at about 325 degrees F, so summer sun isn't going to do it. Now, if it was milled because of something other than age/deteriorating, it might kinda bond a little bit.
Applying a prime of asphalt emulsions does do a lot, and sand the top. You might be able to find a contractor locally, as every paving outfit will have a tack truck or atleast a tack wagon. It's getting them out to do a small homeowner job that is hard.
/ Dry asphalt seal #9
Asphalt Millings or RAP "Reclaimed Asphalt Product" is the correct name. It is often used to do driveways and minor side streets adjacent to mainline roadway resurfacing. They will prime it with asphalt emulsions and spread sand on top; as someone mentioned, the sand absorbs some, and keeps it from tracking.
Whether it's a DIY type thing or best left to a contractor kinda depends on size, what stuff you have laying around, and your budget.
/ Dry asphalt seal #10
This is a semi local paving company/Asphalt plant owner that actually lists vendor pricing (which is pretty rare). This is Not the exact product, this Trackless Tack has a wax in it to avoid tracking it onto the road once it "breaks", Special MS emulsions is likely the best bet. It's not straight AC, and isn't ran at the same temps, and can be watered down somewhat and still be effective.
I read a study once by Oklahoma DOT that studied using higher application rates of more watered down prime, and found good results.
Atleast knowing the product name might get you pointed in the right direction.
/ Dry asphalt seal
All great answers! Sounds like it’s way over what my body can do by myself at my age, so I’ll look into a contractor. Thanks all for your feedback. This site is great.
/ Dry asphalt seal #12
It looks like special MS isn't very widely used anymore, but a SS, Slow set, vs MS, medium set, Slow Set would be fine as well. It actually would give you more time to spread sand on it. That can be done with shovels and sling it, if it's fairly small, a 3 point spreader, or a sand truck. You over apply the sand, and then either let rain wash the extra off, or you could broom it off a few days later. In the mean time, you can drive over it fine. You wouldn't want to drive over the bare prime.
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
Metal Hog Feeder (A65640)
Metal Hog Feeder...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2009 Ford F150 (A64194)
2009 Ford F150...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2013 International WorkStar 7500 Side Loader Garbage Truck (A64194)
2013 International...
