Diesel fuel #1 and #2
/ Diesel fuel #1 and #2 #1
careyo63
Elite Member
77 Yanmar YM2000 63 Ford 2000
I do not have or seen this option for the #2 diesel. Interesting read so I'm going to be looking into this. If or when it does become available. Off Rd. is available local. Just came up about Extra stinky!! ? It could be the #2 JS..:oops:
/ Diesel fuel #1 and #2 #2
A little reminder that today's ULSD is not what old timers remember as diesel, and ULSD is a very different fuel in many ways. Importantly for older engines, it has much less lubricity.
Yanmar recommends against straight #1 here, and quoting a huge drop in fuel efficiency;
#1 diesel is a low temperature fuel, and one that in my opinion is mostly inappropriate as a fuel for the lower 48 for almost all of the year. A low temperature fuel means a lower cloud point temperature, a lower gelling temperature, lower viscosity, and lower lubricity temperatures. Unless you are experiencing waxing/cloud point or gelling issues, I think that it is not advisable to run #1 diesel, especially, especially, in an older engine. If you are having gelling issues, an anti gelling additive is probably a better solution, especially for an older engine like a Yanmar. It is possible to blend #1 and #2 for low temperature work, but I would not do it myself.
There is a nice discussion here on the cloud point of diesel fuel, gel temperature, and, of course water (ice) in diesel.
Lots of discussion here on TBN;
When burned #1 diesel doesn't smell that much different to me.
One final point, #1 diesel is close to jet fuel (JetA1, JP-5/8) in terms of hydrocarbon composition, making diesel #1 much more like a solvent, dissolving materials. JP-5/8 has been shown to be very hard on o-rings, rubber tubing, and internal corrosion.
All the best,
Peter
/ Diesel fuel #1 and #2 #3
I've never seen #1 or #2 advertised as such, so no idea what I'm burning. Guess I'll have to walk in one day and ask...
I'm thinking the old school off Rd. now! Low temp. here in my part of Ga. very seldom goes below freezing. Nights for a few Months.. I do know the owner of a local store who does sell Off Rd.. and Ask what his actually is? Off course he has Reg. Pump Diesel Chevron. Which is what I've been using. Can't see the fuel filter or in the fuel bowl on the Yanmar with the Red Dye in it. I just checked and I have a new backup fuel Filter NAPA. so Off Rd. it is! It's due to come out anyways.
/ Diesel fuel #1 and #2 #5
Generally, I've only seen it in select stores in the very northern states, and it was more common in my experiences many many moons ago, like kerosene.
All the best,
Peter
/ Diesel fuel #1 and #2 #6
#1 diesel is kerosene, or kerosene is #1 diesel fuel. Your #2 home heating oil is the same as #2 diesel.
/ Diesel fuel #1 and #2 #7
They are close in hydrocarbon composition, and in some places may be identical, but I don't think that can be relied upon. In earlier times, when fuels were less refined, and defined by the boiling point of hydrocarbons, the composition could, and did, vary substantially by the incoming crude and particular refinery, e.g. the amount of aromatic hydrocarbons. With modern fuel standards, diesel fuel composition is much more tightly regulated than fuel oil. So, #2 diesel fuel contains additives to meet standards that #2 heating oil may not. Ditto #1 diesel vs kerosene. Rather like gasoline vs. camping fuel.
If one lives in an area with a fuel limited supply or demand, the local fuel distributor may only truck in #2 diesel and sell it both as over the road fuel and as heating oil, but I think that is a supply / demand and local storage item.
I have acquaintances who have successfully run #2 heating oil in their farm equipment, and others who tried and paid the price of redoing their fuel systems. Again, I think it is a local thing, and I wouldn't rule out my buddies accidentally pumping some sludge out of their heating oil tanks.
Personally, I haven't seen a kerosene pump at a fuel station for years, but again, I am sure that there are locales where that is not the case.
YMMV!
All the best,
Peter
/ Diesel fuel #1 and #2 #8
Fairly common here in middle Tn. I can think of 3 kerosene pumps within 2 mile radius of my house
/ Diesel fuel #1 and #2 #9
At a guess what do you think that the demand is? Kerosene heaters? Lighting?
All the best,
Peter
My grandfather had a Coal miners helmet lamp that used Kerosine! INKY. Early 1900's. Hung in his barn for Yrs..
Chevron owner wasn't in. Didn't bother to ask the cashier. I know him well and he has somewhat good English. I filled my can with Off Rd.. Made sure I still have the new Filter in the box. I'll be changing it in about 50 Tach. Hrs. it looks like.
/ Diesel fuel #1 and #2 #11
We have kerosene, off road, ethanol free, and standard #2 diesel pumps here in N. Idaho , along with standard ethanol blended fuels.
Kerosene is crazy expensive.
/ Diesel fuel #1 and #2 #12
All the best,
Peter
At a guess mostly sales in winter. Kerosene heaters and mixing Kerosene with their diesel in winter to prevent gelling. Local guys say 1 gallon of kerosene to 10 gallon of diesel prevents gelling. Myself, I run an anti-gel to prevent gelling and run straight # 2 diesel.
/ Diesel fuel #1 and #2 #13
I-used to do that when i lived in Montana in the 1980’s.
Todays modern diesel fuels, at least in the pacific northwest, have a winter blend at the pumps. I hold off refueling my storage tank that i use for winter snow plowing until winter blends arrives at the stations.
Ive never had gelling occur in the last 29 years ive lived here. I use no other additives.
/ Diesel fuel #1 and #2 #14
I have had gelling issues over the years.
Now days my winter tractor tank is a 30% blend of #1 and #2 "fuel" oil (30% #1 and 70% #2) along with the high dosage of anti gell. If and when the forecast is calling for -20F I'll add a bit more #1 or kerosene to the tractor tanks.
/ Diesel fuel #1 and #2 #15
Fleet farm in Cedar Rapids has a pump for kerosene. I normally will just add power service to my diesel for cold Iowa weather. However, cenex stations here put out a winter blend of diesel.
/ Diesel fuel #1 and #2 #16
That is what I was always taught. If you add red dye to either one, then it becomes off road and no taxes are charged.
Consider this...
A gas station owner calls the distributor and orders 3000 gallons of diesel to top off his 5000 gallon underground tank, The trucker picks up whatever liquid the distributor says was ordered. (doesn't matter what it actually is) and the trucker comes to the station and dumps the 3000 gallons into a hole marked by a color chart on the ground. There are so many places in the chain of that transaction where things can go wrong, it isn't even funny. Now... you the customer go in and buy some diesel and you have an issue with it, taking out the pump on your diesel engine. What caused it, was it the refinery? Was it the distributor who pumped the wrong stuff into the tank which mixed what was in the underground tank or was it the trucker who is color blind and put it in the wrong tank?
There are so many ways this can go wrong, and yet we thinking that it was because it was #1 or #2 diesel or kerosene or that off road doesn't have the proper lubricants because it colored or whatever doesn't really include these variables.
David from jax
/ Diesel fuel #1 and #2 #17
When it gets really cold I blend kerosene in with my diesel, at about 25%. I think this last winter it was $5.50 a gallon. 5 gallons often lasts me two winters though.
/ Diesel fuel #1 and #2 #19
In my area much of it is for heating, there are still lots of exterior heating tanks that get kerosene, also works good in salamander heaters with less smoke and fumes then #2. And then to cut #2 in the winter.
Grandfather used Kerosene in WV.. Which we called it Heating oil as kids. Coal before that. They finally changed to Natural gas when it was finally available for delivery.
I'm all Elec.. and use a Heat pump/AC.. No gas!. I will have to switch the heat to just Electric heat a few times a yr. but very seldom. Mid 30 Deg.. When I do have to switch it over you can bet the Elec. bill goes up substantially. The bill will be almost double. I do like gas stoves for cooking which I have on the grill.
The Off Rd. Diesel I used does run better. Haven't used it in yrs.. You could tell it. The Yammer hammer was louder and seemed to run with more power mowing. Pretty much like running High Test Gas to just plain Reg.. Just like old Big block 4-barrel days was a noticeable difference using it.
