King kutter tiller loud banging
/ King kutter tiller loud banging #21
Any update, after the weekend? I also have an oiled, greased new/untested KK tiller sitting in the shop, waiting on weather...
You ARE engaging the PTO at a slow speed, ramping up RPM, then engaging the ground slowly, right?
Is it a continuous banging, or just one bang? Is it slower banging (tine rotation speed) or a fast banging (PTO shaft speed)?
/ King kutter tiller loud banging #22
recently purchased king kutter tiller. Put oil in and grease tiller as well as pto shaft. Had to cut down pto shaft by 2.75” to fit tractor. When pto in engaged all is well but once tiller touches the ground it make a loud banging sound. Any idea what the problem could be?
Some pictures might be helpful for someone to figure out what the problem is.
Since you are a new member I’m also wondering how much previous experience you have with operating 3 point hookup PTO equipment ?
/ King kutter tiller loud banging #23
If you haven’t engaged the ground I would guess the drive chain. Engaging the ground would put it under tension and tend to quiet it down.
/ King kutter tiller loud banging #24
He said it's Gear Drive. We're all still waiting an update, though.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
