Well pump
/ Well pump #22
According to this picture if cover with start capacitor and relay "slip" connects with wired terminals and with what appears to be check valve below pressure switch, all you are missing is L1/L2 (from fuse/circuit breaker) routed through pressure switch to pump control box....
image-jpg.3253057
/ Well pump
image-jpg.3253057
Wired it in this afternoon and everything works as should.
Thanks again to everyone that commented
/ Well pump #24
ok now that's done, let's hear from everyone who only reads the first post and then answers some un-asked question incorrectly for the next four pages and weeks...
/ Well pump #26
Sorry WinterDeere, responded to your post before finishing the thread and caught your correction.
/ Well pump #28
It actually wasn't a mistake, but rather a failure to remember that styles have changed over time.
While it seems most well controllers have the cap and relay in the lid now, probably so that unawaware DIY'ers aren't sticking their hands into a box with a capacitor that may be holding a charge as high as 340 VDC, older ones mostly had these components in the box itself, not the lid. I'm more used to seeing that older style, as I own and mostly work on older homes.
Bonus points for anyone who can figure out why a capacitor on a 240 VAC circuit may be charged as high as 340 VDC. :p
/ Well pump #29
I have in my possession a 1968 Franklin control box with the guts in the cover. You must have some really old stuff where you are.
/ Well pump #30
Maybe! It can be tough to tell the age of a box mounted to a wall in a basement utility room. I wonder though if Franklin was just the first to switch to this style, before some of the others.
/ Well pump #31
I believe Franklin was the first with the quick disconnect control box. Most others at this point make a box that is interchangeable with Franklin.
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2018 DRAGON 150...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2008 Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A61569)
2008 Regal 2565...
