Branson 2400H
/ Branson 2400H #1
dinoedwards
kubota
2 things, is this fluid ok for this unit? I use it in Kubota G1800.
Also I think the 3 point arms are backwards.
Just ordered bonded dowty washers to fix leaky 3rd function valve.
/ Branson 2400H
The service manual sucks it says use 10w40 oil but why not list 15/40 diesel oil?
What's best?
/ Branson 2400H #3
Yes your arms are backwards - switch left and right lower arms. Also I finally bought a set of pin style connecting links for the lower arms - holds them out for attaching 3PT implements then you can adjust in once mounted - shoulda done that years ago.
Did the dealer change the fluid at 300 hours? If i recall it has 325 hours on it? If this is to "top off" the fluids it's probably fine, but if youre going to change it the TSC AW 46 is inexpensive $50 for 5 gal, Then there are other "better" fluids out there - JD Hygard and a others - see what your dealer recommends.
/ Branson 2400H
Just went over 400 and they just did full service before sold.
Yes, top off after fittings repair this weekend.
Bought it at 394hrs.
Where did u get those pin links?
/ Branson 2400H #5
/ Branson 2400H
Not bad for $80
I got my o-ring washers in, no more leaks and now have a few in the kit for future.
Turned 3 point around as well.
Seen a full set of Kubota's for $250 on MP but I need a box blade next.
/ Branson 2400H #7
No - its $40 for the set - cheap and they work well.
/ Branson 2400H
I see Texaco TDH oil, 1893 in one manual and think no longer made.
I see TSC AW 46 or Mobilfluid 424.
Have a small leak on dipstick o-ring and might as well change filters and check screen.
Will AW46 hurt warranty? What filter are u guys using?
FE9105000A
TA00616986A
Also going to use 15/40 engine oil instead of 10/30.
Thoughts
/ Branson 2400H #10
I'm confused - if the dealer just did the major service at 350 or so hours - why do it again so soon? Is the hyd fluid milky or discolored, or smell burnt? The same with the engine oil - no need to change it so soon.
If manual says AW 46 Trans fluid, then get the TSC $50 for 5 gal. For engine oil I use the Rotella 15-40.
For the Kukje A1100N2 engine in your machine the search on TBN is a great tool - check this thread.. Oil & Fuel - TYM T264 50 Hour Cross Reference Parts
/ Branson 2400H #11
I can't check the TSC AW46 oil specs because it won't let me access the TSC website but seeing the AW46, tells me it might be just hydraulic oil.
You want universal tractor transmission oil, also called UTTO, since your tractor has wet brakes. This oil has the necessary additives for wet clutches and wet brakes, which straight hydraulic oil has not.
The operators manual calls for the Texaco TDH oil which is a tractor transmission oil.
/ Branson 2400H #12
These are the specs posted for the Universal TSC Fluid - not the ISO 46 Hyd Fluid,
Traveller 5 gal. Premium Tractor Trans/Hydraulic Fluid is designed with modern farm equipment in mind. It employs a common sump to lubricate hydrostatic transmissions, differentials, wet brakes, hydraulics and final drives gears, and it can be used with a variety of off highway machinery, industrial tractors, final drives and more. Thanks to this hydraulic fluid's universal compatibility, taking care of your brakes and gears is simple. Meets J20C standards.
Premium hydraulic fluid helps reduce wear and brake chatter and helps extend equipment life
Formulated to provide superior protection for modern farm equipment
Special multigrade (SAE 10W-30) fluid blended with the highest quality lubricating oils and the most technologically advanced additive system
Employs a common sump to lubricate hydrostatic transmissions, differentials, wet brakes, hydraulics and final drives gears
Designed for low temperature pumpability, excellent thermal stability and gear protection
Temperature rating: -44 to 439 degrees F
Universal hydraulic fluid recommended for 100+ OEM applications (see label for complete list)
Meets J20C requirements
Includes 5 gal. bucket of tractor hydraulic fluid
/ Branson 2400H #13
Oh that's better. Thanks for the info. I just get "Access denied" every time I try to access the TSC website.
/ Branson 2400H
Yes, just done at 350 but I have to repair an o ring and may lose lots of fluid.
The o ring is on dipstick mount, 2 o rings.
Sorry didn't make myself clear, Manual says TDH 1893 but I read that that AW 46 or Mobile 424 replaces it.
I'm using JC20 to top off which I use on my small Kubota.
Bottom line is which hydro fluid is best for Branson 2400H? Thx
/ Branson 2400H
Why does Hansen Equipment say NEVER USE AW FLUID in his post?
/ Branson 2400H
OIL We run 15w40 cj4,ci4 and newer ck4. Hyd/Hst we sell gulf transcrest, this is a UTF/MTF oil. A good high spec to look for is JD20c or Kubota UDT Never use a AW or the out dated 303. Front axle 80W90. Hope this helps and enjoy your new tractor.
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
JOHN DEERE 14' FLAIL MOWER (A63745)
JOHN DEERE 14'...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
All-Aluminum Timpte 720 Trailer (A63118)
All-Aluminum...
2022 Husqvarna Z560L Zero Turn (A63116)
2022 Husqvarna...
