   / Your last generator Maintenance Run #7,411
Back ice-storm here, Central/East Ontario.
Out for 14 hours @ home, 7kw Briggs did fine. Needed the sump pump moving a LOT of water, job done.
Electronics..... some interesting things along the way. Got up @ 3am, could see this area not yet reported to hydro (Canuck Elec Util), so called on my wife's cell that I had the map on...... after about 10 minutes, it wasn't a "normal" call drop (lousy cell coverage), but got a BIG pop-up that said "This network is not supporting Voice calls at this time". Shedding load, with the tower on Emerg pwr.....
So, one of the reasons I still have a landline, is for times like yesterday...... spent 30 minutes on hold, to get someone live to report the outage early. Then..... got my gen running in good time.
New UPS doesn't like the AVR on my 7kw (kept switching back to battery, when the 7kw was under light-load). Haven't studied it further yet.... something for my ToDo list.
Internet was down, I'm on cable, and the pedestal boxes only have enough battery for a few hours. Buddy 2 hours away (same storm, but hit worse), had fibre down for a while too...... Starlink does look good, for times like these....
Hoping you don't NEED to run yours soon, but wishing they start-up fine if you do....
Rgds, D.
I have a smart meter on the house, and this auto reports power outages.
   / Your last generator Maintenance Run #7,412
Yep, been running my Reds for about 12 hours, alternating between the two, since Sunday due to the ice storm here in eastern Ontario. Restoration is promised for tomorrow late. Time will tell…
   / Your last generator Maintenance Run #7,413
Rgds, D.
UPS's generally don't like non inverter generator due to the Frequency moving up and down more than .5 hz
   / Your last generator Maintenance Run #7,414
I have 5 ups devices. They never have any issues on my 22kw generac.
   / Your last generator Maintenance Run #7,415
I have 13, never tried a generac, is it an electronic governor? I have tried 4 different non inverter generator's all the cheap units don't handle the generator if not inverter.
   / Your last generator Maintenance Run #7,416
Never a bit of trouble with my 25KW pto unit, the ups's just charge backup and sit and wait.
   / Your last generator Maintenance Run #7,417
The 22kw generac does have an electronic governor that uses a stepper motor to control the throttle governed by output frequency. My UPS’s are fine with it as well.
   / Your last generator Maintenance Run #7,418
yea it prolly holds the hertz better, the mechanical linkages don't seem to be able to keep under .5hz which most of the cheap units require.
   / Your last generator Maintenance Run #7,419
What popgadget says…… they also have a low thd so work great with electronics overall. When mines operating during power outage, nothing flickers or moans. Hard to tell im not on utility power.
   / Your last generator Maintenance Run #7,420
Me too, but it's unable to communicate to the grid and neighbors are a long way off.
They still come and read it monthly and this is for many around here. 😆
Iirc at the time, they were getting highly paid by BO's administration so it was a profit item for the utility.
Kubota L4701 (A53317)
2026 tilt trailer (A56859)
2026 tilt trailer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
