HP increase module? Deere 3038e
/ HP increase module? Deere 3038e #41
I understand...but $600 vs $50K when you just need a little more power?
or.....just bump up the throttle some. :rolleyes:
"I tried module turned off & higher rpm, all it did was spin tires."
/ HP increase module? Deere 3038e #42
Do they post dyno results?
/ HP increase module? Deere 3038e #43
I’d guess it up the boost at lower rpm’s and bumps up the fuel. I seriously doubt it will use less fuel for you, or at least not enough difference you would notice. It might also alter injection timing.
/ HP increase module? Deere 3038e #45
It would be simple enough for them to post a dyno graph.
/ HP increase module? Deere 3038e #46
Ya, flipping a switch doesn't add weight & traction. Unless it's activating fwa or a diff lock. Spinning tires needs you need more weight or traction, not more power.
/ HP increase module? Deere 3038e #47
No way you save fuel & increase power at the same time. Anybody that tries to sell you something that does both is selling snake oil & I wouldn't trust any of their claims
This statement is false. A tune can add more power and burn less fuel by ignoring emissions. Machines can run leaner during light loads and burn less fuel but this increases emissions regulators don’t like. Obviously when at max load it’s burning more fuel but unless you are at max load 100% of time a tune can be more efficient at less than max load and have more power while netting overall less fuel usage.(depending on the low load vs high load ratios a person operates the machine at).
That's correct. The higher rpm the more likely you break traction.
Our farrier got his Ram 3500 pickup stuck off the road. I pulled him out going uphill in snow with my 300 cu in six 4x4 F150 in granny gear at idle rpm. If I released clutch at 5,000 rpm, what would happen?
HP is just a mathmatical derivitive of torque, curves cross at 5252.
I'm elated having tractor with increased torque at a lower rpm.
Another example is suppose I bush hog running it at 550 PTO rpm and engine rpm is at 1600. Going uphill either engine bogs or rpm drops. With more hp (torque) using the module all is well.
Sure...I could run tractor at 2500 rpm...but now hog is running at 1000 rpm which I don't want to do.
And $600 is much better than paying, say, $30,000 difference when this works just fine.
/ HP increase module? Deere 3038e #49
What????🤪 So, you are saying that Deere didn't match peak power with 540 pto speed? Your tractor has a 1000 rpm pto on it?
If you are always running the engine that slow while doing work, it is no wonder you want more power.🤨
What???? So, you are saying that Deere didn't match peak power with 540 pto speed? Your tractor has a 1000 rpm pto on it?
I don't understand your confusion.
My bush hog recommended rpm is 550. For that to happen the engine must run whatever rpm gives 550 PTO rpm. If engine is at 1,600 rpm that gives 550 PTO rpm.
It's an example...I'm not at the tractor to verify 100%...but close.
This year bush hogging I won't have engine bog or rpm drops which is my concern.
/ HP increase module? Deere 3038e #51
I always thought the yellow gear thingy was the 540 PTO indicator. Always learning something at TBN
Ok...I stand corrected. Optimal cutting is 540 rpm which is 2500 engine rpm (roughly). I was trying to make an example...my mistake.
If I have light duty cutting IMHO a bit lower tractor and PTO rpm is okay. Otherwise why even have a throttle. Everything should simply have a solenoid switch. Start tractor, flip switch and it's at 2,500 rpm.
My point is the module increases power. Fuel usage remains to be seen.
It's not for everyone and everyone does things differently...right or wrong.
/ HP increase module? Deere 3038e #53
I don’t understand when people talk about it running leaner? It’s a diesel, they vary the amount of fuel injected to make more or less power. The only other way would be to vary the injection timing and I’m not sure there is a lot to gain for power there.
Coming from a Dodge with a Cummins that had a chip on it they increased boost and fuel at lower rpm’s. This was pretty much well known on how they were getting more power. In the case of the op and his chip we don’t really know what it’s doing but educated guesses can be made. If he has EGR it could be turning that off I suppose but the way tge chip makers have been fined I doubt it.
/ HP increase module? Deere 3038e #54
Wasn't trying to be nitpicky, sorry if it came across that way. In your simplified calculation for pto speed I think you may have neglected the effects of ground speed and terrain. When doing light mowing on basically flat ground (5MPH and 1600 engine rpm) a bushhog wouldn't notice the difference. Same settings going uphill and the engine starts to bog. Heavy grass starts to bog. The engine/gs/pto combination doesn't provide enough torque to do the job.
/ HP increase module? Deere 3038e #55
A person may think that they are being easier on the engine by running at a slow speed but, once there is a load on it to bog, the governor has whacked the injector wide open and the turbo is creating tremendous heat. At low rpm, it doesn't have the water pump speed, fan speed, cooling intake air for the turbo, etc to operate under those conditions.
I'm trying to explain from my recliner, I'm not at the tractor or paper manual in hand...so I called them. 812-618-9166
The tech said at end of the fuel rail is a pressure sensor. I unplugged it and module leads now go between the two. What it does is increases pressure as needed. They said simply call that number if anyone has any questions.
I told him I can now work at a lower rpm in 4WD and it won't spin tires, it just has more torque and he said that's exactly right.
More hp & efficiency means more power and less fuel used (efficiency).
Any questions simply call the company. All I know is it's money well spent and I'm happy with 30% more power.
/ HP increase module? Deere 3038e #58
It is just bumping the fuel rail pressure.....read about it.
I did:
This diesel performance module is designed for fuel economy with up to 30% increase in horsepower and fuel savings up to 10%-20%
Adjustable with a three position switch
You can adjust the power on the fly, Stock, +15%, and +30% HP
The module does not flash the ECM, instead it receives the data from the ECM, optimizes the signal to the engine improving the fuel efficiency and power
These savings ensure a quick return on investment so you can enjoy greater efficiency and less cost
Plug-and-play connectivity means there is no need to cut, splice or modify engine wiring
/ HP increase module? Deere 3038e #60
From what I read, the cheap way of adding fuel is lowing the voltage from the fuel rail sensor. The ECU then bumps the pressure up to compensate the faked low pressure signal. There is normally a pop-off valve to protect from over pressure but they don't survive being popped often. Some sellers of chips have stopped selling these types.
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2022 CATERPILLAR 914 WHEEL LOADER (A65053)
2022 CATERPILLAR...
2015 FREIGHLTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2015 FREIGHLTLINER...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2016 Toyota Tundra Ext. Cab Pickup Truck (A64556)
2016 Toyota Tundra...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
