Farmall Super C charging too much
   / Farmall Super C charging too much
I can't reach my friend right now but am virtually certain it was volts on his meter. Amps were on my tractor gauge.
   / Farmall Super C charging too much #12
yea you were suppose to confirm the amperage readings, not the voltage readings, your voltage numbers also seem off if this is suppose to be a 6v tractor, did you buy a 12v regulator?
It came this way last year and I've had more pressing things on the tractor. The other battery was bad so I let things go. This is the regulator it came with and does sound like you might be on to something.
Last summer I had the generator tested for output and the the shop said it put out to spec.
Why did the amp meter on the tractor go to zero at max rpm? Then go back? Sorry to ask such dumb questions but it's been decades since I've done this and forgot things.
   / Farmall Super C charging too much #14
you need to slow down and do 2 things, have your neighbor come back, have him check the voltage with the tractor off, idling and full throttle, you then need to check the amperage at idle and full throttle.
if the voltage is over 10v at full throttle, you need to stop before you destroy another battery, it sounds like the wrong regulator was installed.
Will do. Thank you.
The battery is new and I charged it before installing it. Across the terminals before starting it was middle 6's volts. At loping slow idle it was 7.7 volts and around half or a little more was over 8 volts and gaining fast. It would have gone over 10 at high speed so I shut it down.
   / Farmall Super C charging too much #17
its the wrong regulator, looks like a 12v regulator, you need to find or have some one tell you the proper pn for the regulator, i think you will find its wrong.
Thanks you for your help. Decades ago I knew all this stuff but not now.
   / Farmall Super C charging too much #19
Standard Motor Products/SMP VR214 is the correct voltage regulator for your tractor. O'Reilly's Auto Parts is the least expensive place to buy them. https://www.oreillyauto.com/detail/...oltage-regulator/std0/vr214?q=SMP+VR214&pos=0
I've tried as lot of them, and this is the best one I've found that will last. I have them on 4 of my tractors, one has been on my one Super C going on 6 years with no issues. I tried one from TSC years ago and it lasted maybe 30 minutes. One from NAPA lasted 45 minutes on the 240U. I put a SMP VR214 on it 3 years ago and still works great.
They aren't cheap but they last. The one from NAPA that lasted 45 minutes was $75. The first one's I bought were still made in the U.S.A. but don't know if they are now or not. I contacted SMP about one for my Massey 35 to get the correct one. He did assure me that that one was still made in the U.S.
Thank you. I have heard bad things about the cheapie regulators from parts unknown and would rather pay up to not have a failure in the middle of a 30 mile tractor ride with a row of unhappy guys behind me.
What is the wire and resistor for that's in the kit? I recall some generators used something extra like that but not sure on the details.
2019 Ford E-450 Super Duty Passenger Bus (A48081)
2019 Ford E-450...
2025 66in Dual Cylinder Grapple Rake Skid Steer Attachment (A49346)
2025 66in Dual...
2009 Toyota RAV4 SUV (A48082)
2009 Toyota RAV4...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
GM Coach Bus (A50860)
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
