What is the highest HP Kubota farm tractor made with a Hydro Trans ?
/ What is the highest HP Kubota farm tractor made with a Hydro Trans ? #21
OP: good title question. another related question may be why Kubota M series tractors do not offer hst in their higher HP Utility models... i'll let someone else explain, but i sure do like my manual/ hyd shuttle model, best of both worlds. thankfully my knees are not a problem for shifting. regards
also maybe explain what your tasks are with your hst preference
You know you don't have to use the clutch to shift right? Shift your shuttle into neutral before changing gears than go back to forward.
/ What is the highest HP Kubota farm tractor made with a Hydro Trans ? #22
Love the hydro trans on the Kubota M59/62. Can’t beat it for close quarters maneuvering at 540pto operations. The loader is powerful but not removable except for the quick attach bucket. Easily 8,000# with loaded tires and my added accessories in 3pt mode. Rated at 45hp pto is lower compared to some comparable ag tractors. Compact size and ample operator station is easy to operate in tight situations.
/ What is the highest HP Kubota farm tractor made with a Hydro Trans ? #23
HUH?, there's three dairy farms just around me that run Fendts on their farms!
SR
OK, that's good to know. Any idea how they like them, how long they have had them, etc.? Any cold start issues?
/ What is the highest HP Kubota farm tractor made with a Hydro Trans ? #24
on the M series hyd shuttle, clutching is required for changing gears, the hyd shuttle is used to change directions w/o clutch use. it really is the best of both worlds if a person is able to clutch while shifting.
many here prefer the hst for their sub & compacts. i have always preferred gears, fortunately there's choice out there, regards
/ What is the highest HP Kubota farm tractor made with a Hydro Trans ? #25
No, there is still a 2000 lb difference. Looking at the overall frame construction and the thickness of metal and fastenings will give an idea of were the extra metal was used. The M62 loader lifts nearly twice the weight & the TLB is set up to handle loader stress.
They seem to be differently built, but with a similar engine and transmission.
Here's what I'm coming up with from the various manuals:
8800 lbs M62 w/ loader, BH, buckets.
4400 lbs L6060
1900 lbs L1055 loader w/ bucket
2000 lbs BH92 Backhoe w/ bucket
8300 lbs equipped like an M62
/ What is the highest HP Kubota farm tractor made with a Hydro Trans ? #26
It gets cold here and I see those Fendts working all winter long, so I'm betting they start just fine.
Only complaint I hear about Fendt is how much they cost.
SR
/ What is the highest HP Kubota farm tractor made with a Hydro Trans ? #27
He means there isn’t any near Him or know of anybody that has one to go look at or try.
Same thing here for me too.
I’ve seen some at a Ag Show 300 miles South of me a few years ago.
They just dont have the dealer network to support ppl to buy / svc them.
Their more popular thru the mid west with all the big row crop farming.
This is what he said, and I live in the US.
In fact, I can't find anyone in the US who owns a Fendt.
…many here prefer the hst for their sub & compacts. i have always preferred gears, fortunately there's choice out there …
I liked the Hydro for mowing with a RFM because of varying your ground speed so easily depending on grass depth.
I like gear trans for farm work applications.
Each has their advantages.
I only was seeking hydro option for poultry house work for the ability to go ALL speeds UNDER 1mph like my current JD 5115M 48spd trans will.
NOBODY around here has a Fendt either. Nobody.
/ What is the highest HP Kubota farm tractor made with a Hydro Trans ? #30
absolutely agree that application is entirely personal & task related. consumers today are fortunate to have so much choice in machines, not always so in the past
regards
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2020 John Deere 6120E (A60462)
2020 John Deere...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2012 ALTERFER  CAT GENERATOR (A60736)
2012 ALTERFER CAT...
2011 CIRCLE M  35 GOOSENECK (A60736)
2011 CIRCLE M 35...
