What is the highest HP Kubota farm tractor made with a Hydro Trans ?
   / What is the highest HP Kubota farm tractor made with a Hydro Trans ? #11
What current model # is the biggest Horsepower farm tractor that Kubota makes with hydrostatic trans option ?
Kubota doesn't have any FARM tractors with a hystat tranny.
SR
Certain vegetable farming, snow blowing & stump grinding requires these low speeds.
Very few & unique applications.
New JD ML series with the Power8 trans has a creeper gear option but they are Very Expensive & Super Rare being hard to find unless you special order one taking months to come in.
   / What is the highest HP Kubota farm tractor made with a Hydro Trans ? #13
I have been going through this same search for several years now, and there is a very unfortunate gap in product offerings between HST tractors which top out around 60-65hp and around 5000 lbs, and tractors with a CVT that start around 100 hp and 11,000 lbs. That's a really big step up in weight and physical size. In between, your only options are manual shift, and a few mixed manual/power shift options. The only thing with full range and gear power shift was the Deere 5R which was only built for a few years ending around 2022. I have driven a couple of them and they are nice, but not the same as an HST or CVT, especially on hilly, uneven terrain.
As noted, Fendt offers the 200 line at around 9500 lbs, so is the smallest available. But so far my interactions with Fendt have been very disappointing. It's been probably 3 weeks of trying to get a PDF manual so I can see what the tractor actually does, how it works, understand ballasting requirements, tread width settings, SVC operations and options, etc. But nobody can produce a manual for me, or tell me how to get one. The latests is that Fendt told me a dealer can order one for me if I want to buy one. I might do that, but I have become concerned about Fendt is other ways lately. There are only two 200s available for sale in the US, and I can't find anyone who owns one. In fact, I can't find anyone in the US who owns a Fendt. I see lots being demoed by YouTubers, but nobody then buys one.
Brian's Farming in Ohio bought or leased a combine, and last I saw it was being trucked off for repairs.
I found a guy in Canada who owns several Fendts and none of them other than the 1000 model will start in the cold, despite block heaters. And if he can get them started they pretty promptly shut down because of DEF issues, and they are constantly throwing error codes. A recent video was of a 500 series being towed onto a trailer and trucked off for replacement of the main wiring harness because it was destroyed by leaking DEF. He loves them when they are working, but he's in the process of switching back to Deere because they never work when he needs them. It gets real cold where I am (-10F currently) so reliable cold weather operation is essential. Now the Fendt 200 uses the Agco 3 cyl engine same as the Massey 4700, so probably different, but I don't want to be the one to find out. I'm just concluding that Fendt would be a massive risk, and I just don't have a lot of patients for stuff that doesn't work.
I agree on Fendt not having enough networking or dealers here in the SouthEast USA.
Deutz is the same way.
I wouldn’t dare buy either Simple because of this.
Closest Deutz dealer is 130 miles away over in AL & up in TN.
I don’t even know of a Fendt dealer Here in North GA SMH
   / What is the highest HP Kubota farm tractor made with a Hydro Trans ? #15
SR
No, but they do make a tractor built even heavier than a FARM tractor, and it does have a six speed HST. It's the M62 with 6 speed HST+ tranny, weighing in at about 8000 lbs. It's basically a heavily built low profile TLB for medium duty commercial use.
It can be ordered with the 3pt hitch instead of the backhoe.
   / What is the highest HP Kubota farm tractor made with a Hydro Trans ? #16
I think it's essentially the same capacity-wise as an L6060. 63 vs 60hp, same HST transmission (3 ranges plug hydraulic hi/lo), and I expect the weight is abotu the same when you consider that the M62 weight includes loader, bucket, and backhoe. If you equipped each similarly, I expect the weight would be about the same.
M62 is equivalent frame size wise to a 4k series JD.
Their pretty small & light compared to a JD 5k 4cyl
   / What is the highest HP Kubota farm tractor made with a Hydro Trans ? #18
No, there is still a 2000 lb difference. Looking at the overall frame construction and the thickness of metal and fastenings will give an idea of were the extra metal was used. The M62 loader lifts nearly twice the weight & the TLB is set up to handle loader stress.
They seem to be differently built, but with a similar engine and transmission.
   / What is the highest HP Kubota farm tractor made with a Hydro Trans ? #19
HUH?, there's three dairy farms just around me that run Fendts on their farms!
SR
SR
He means there isn’t any near Him or know of anybody that has one to go look at or try.
Same thing here for me too.
I’ve seen some at a Ag Show 300 miles South of me a few years ago.
They just dont have the dealer network to support ppl to buy / svc them.
Their more popular thru the mid west with all the big row crop farming.
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
LOT: (80 approx.) Gallons of Chevron Delo 400 XLE SB SAE 15W-40 Synblend (A59076)
LOT: (80 approx.)...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
FIMCO 200 GALLON FENCE ROW / CATTLE SPRAYER (A52708)
FIMCO 200 GALLON...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
