Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor.
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #1
HawkinsHollow
SE TN
Branson 3015R
All this excavator talk has me itchin'. I have 3 or 4 jobs I need a digging tool for. The only financially feasible options for me in the near term is a Chinese Mini X or a subframe backhoe for my Branson. Of the 3 jobs only one has space issues where a mini ex would more than likely be better. The 3 jobs I have are: Digging out a hillside (12'wide x 40 feet long about 5 feet high at the highest) to make more space and install retaining wall, make a new road into my bottom land (only a couple hundred feet up out of a gully), and flatten an area and install retaining wall off the side of an embankment from the top. The last one is the one with space issues as the landing is only about 20'x15' and squeezes down to about 10' wide at one point.
It seems to me like the tractor backhoe would be a more capable digging tool on my full bodied 30 hp Branson tractor. The only disadvantage in my eyes is the lack of mobility and larger footprint of the tractor/backhoe combo. I could probably find something cheaper than a chinese Hoe in this combo as well. If you could only have one, which would you pick?
I know they say rent rent rent. And I have and am not opposed to it. But renting isn't getting any cheaper and I borrowed a machine this past summer to do my footers and it was nice to not be on a SUPER tight rental schedule.
What would you do in this case?
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #2
The more capable digging tool is the excavator. The tractor with FEL is more capable of dirt moving over distance though it may be cumbersome with a add on hoe. Tractors not originally designed for a backhoe often require you fight having to switch seats.
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #3
I would recommend the excavator it is a superior digging machine by comparison and you will find so many uses for it as time goes on.
For movement, yeah I guess that is true.
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #5
A backhoe for everyday chores. You can always rent an excavator for the few times it is better.
And by "more capable digger" I meant power wise more capable. But movement does come into play.
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #7
A mini X will far outperform a tractor back hoe. Very recently I thought about a backhoe for the tractor, figured if I was going in for the backhoe, I might as well buy a mini. Ended up with a Wacker Neuson 7500 pound machine.
Of course a 7500 lb mini is going to out perform a tractor backhoe. But does a 1.5 ton chinese mini?
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #9
You need to compare in the same weight class.
Many years ago I added a 3pt backhoe to my little MF GC2300. It would dig and do some very light trench work but was a pain to work with. I converted it to a skid steer mount unit and it became much more handy but still rather limited trying to trench. A year and a 1/2 back I picked up a 1-ton gas powered micro-ex and it easily outperforms that backhoe attachment for general digging and trenching (I sold the hoe off). The limitations of the micro is being too light for stumping and too slow getting around. It is strictly a rare use machine for me. But it was dirt cheap and they can be found now for less than I paid.
If I had the money and I would buy a Chinese mini-ex at of least 3-ton for the diesel engine and more refined controls. You can find them now for under $20k in the US.
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #10
I didn't mean to compare the two, just stating what I bought. Tractor backhoes are very limited in what they can do. However, as stated, they have no ground speed and you can't put a plate on them to go help a neighbor.
That’s the info I was looking for. A direct comparison between the 2 diggers. Yeah, I have no false hopes nor great need to dig many stumps. The videos I have watched look this those micros can dig pretty well. It's not a huge amount of digging, nor do I think it will be very rocky. So I am pretty confident I can get it done with one of those chinese diggers.
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #12
Chinese excavator (cheap) .... Buy it, use it, sell it when no more work for it.... Anyway that is my thought process at the moment... The thing is the excavator in more mobile than a BH and can you BH lift 1.5 tons?
Also check out Y-tube videos for $5-8K cheap excavators...
Yeah, I doubt they hold much resale after 50 hours of work. But if it's still working you should be able to get half your money back which would be a win in my book. Did you buy one yet or are you still in the market?
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #14
I haven't been on a chinese mini-x (have been on a couple commercial quality units) but I can confidently tell you that the smallish amount of money between size classes will pay itself back in ease of use. Fighting a machine that is too light to do anything but pull itself over is no fun.
As far as resale value, i'm seeing the small machines for 5k constantly now, and im pretty sure if a 50hr one was listed for half ($2500?!) it'd sell basically instantly.
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #15
I opted out getting one on my T25 for a couple reasons. I use multiple rear attachments and it looks like it would be a pita to hook and unhook a backhoe.
I wasn’t fond of the idea that every time you need to move the tractor back to dig some more, you have to jump off and go to the main seat to move it. Seems like a mini ex or backhoe would be better .
Also the backhoe for my T25 is 7k . Maybe it it were like 3k I could overlook all the negatives.
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #16
Have not taken the plunge (yet)... Only thing holding me back is I only need it for a few weeks to a month removing fire/storm damaged trees but would also be better than having to pay a crew to come and do the work at the sum of $1800 a day... And my SUB compact tractor is not really BH capable... We are talking some financial recover here for resealing it....
Yeah it seems like $4500- $5k is the average for an "almost new" one on Marketplace in my area. Like with 5 or 6 hours on it. I get what you're saying about light weight. I have run a number of larger to smaller minis so I know what to expect from their performance. I would definitely try one out before purchasing to determine if performance meets my expectations.
Yeah, I am starting to see the merits in a dedicated Mini. Not only that but the tractor+mini combo is pretty powerful duo.
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #19
I have both - my B21 TLB and bought the "2 Ton" Terror (Hightop Brand) off ebay last summer - Kubota 722 3Cyl diesel. They arent really 2 Ton - mine is 3450 without the operator, or about 1.8 tons with the operator.
It's very well built for the $ 9500 now on ebay - Kamran Motors sells the same hightop brand and they get good reviews and have the bigger Kubota 902 Diesel. The smaller machines will weigh in about 2000 lbs with no pilot controls, a gas engine and you can get them as low as $4K.
For th $9K ifs a good value, and will dig as good as my BH but where it shines is the 360 rotation and digging and picking rocks etc. as a helper to load the Kubota.
Down side, it's slow to transport. I can see where you would use this alot HH to load your sawmill and i am sure much more
   / Since we are talking about excavators: Chinese Mini X vs. Subframe backhoe on tractor. #20
As others have said, I tried a backhoe on a small tractor years ago and if you only want to dig a hole like for a tree, it works, but if you have to dig a trench or something where you’re moving, it becomes cumbersome as you constantly have to bring in the outriggers move the tractor shut everything up I now have a mini excavator a Kabota, not a Chinese. and I’m very happy with it. I can dig and move and dig and move without having the constant set up required with a backhoe. My excavator is the smallest Kabota. It weighs 2500 pounds. Does everything I wanted to do? I just have to remember to do it slower because if it’s weight limitation and oh by the way, if you wanna move it to another job down the street it’s max ground speed is 2 1/2 miles an hour so pack a lunch
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
