Green Yanmar Problem
/ Green Yanmar Problem
Diesels are much more efficient than gasoline engines, as they are fuel limited. A fair amount of the non-work heat losses are passed through the exhaust due to lean mixtures burnt in a diesel engine.
That said, my apologies, I am still trying to understand your problem. The engine isn't overheating, it runs, and it leaves some coolant in the reservoir. That sounds like normal operation from this armchair. What am I missing?
All the best,
Peter
All last summer it expand into reservoir and failed to return to the radiator. Every third time I would use it I would have take the coolant out of the reservoir and put back in the radiator myself. If you read post#1 you will see what all I have done to solve the problem. Today when I ran it there was no problem [no thermostat and back flushed the radiator, clear water]. The tractor has never overheated just the problem of the coolant no returning to the radiator.
/ Green Yanmar Problem #26
When the coolant expands it goes to the overflow tank and should be sucked back into the radiator. After a few times of running the over tank overfills if I don't take it out and return it to the radiator.
Everything you mention could simply be that needs the hose renewed between the radiator and the overflow tank.
Already did that. I did run again today 2000 rpm for 15 mln with no problems [after back flushing the radiator, removing the thermostat with clear water]. I am considering putting the coolant back in and leaving the thermostat out. I only use this tractor for mowing in the summer. The ym2500 [same tractor uses no thermostat]. If it acts up again I'll do the head gasket.
/ Green Yanmar Problem #30
Are there examples of each?
Yes, you can see examples in this posted thread,
Yanmar - Model Cover Pages
The tractor historian in Japan mentioned this on his site too.
When farmers looked into their fields from a distance and seen the green Yanmars, it took on the name Tree Frog as it looked among the crops.
Translated,
"I can not tell the difference, ... Is that a Tree Frog. Is that really the case here."
Lite Tree Frog Green,
Dark Tree Frog Green,
The Kramp swatch matches the Lite Tree Frog Green,
Translated,
/ Green Yanmar Problem #33
Thanks for posting back the solution to the problem! Most people don’t do that.
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64277)
KNOW BEFORE YOU...
2022 EZ-GO ELITE...
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
