RK24 stuck in 4WD
   / RK24 stuck in 4WD #1
MissFireMike
Bloomington, Indiana
RK 24
Has anyone else had an issue getting out of 4WD? It's a year old. 65 hours on it. I did the 50 hr late last summer. Shifts from Hi to low fine. I have tried in high, low and neutral. I've tried easing on the foot pedal forward and reverse. The lever just won't budge.
   / RK24 stuck in 4WD #2
Welcome to TBN.
Here are a few things to try:
If you have a loader, place your bucket on the ground and dump your bucket lifting the front tires off the ground, watch the tires and they my spin in different directions indicating you had tension in your front axle. The 4-wheel lever should now move freely to disengage it.
If you don't have a loader try moving forward and backwards while turning left and right (travel in forward for 1/2 of a circle, then travel backwards the opposite direction) applying gentle pressure to your 4-wheel drive lever to disengage the 4-wheel mode.
   / RK24 stuck in 4WD #3
On my tractor it is normal for me to stop, put in reverse, slightly back up and then the fwd lever will move out of fwd
Been doing this for 20 years
  • Good Post
Reactions: D&D
   / RK24 stuck in 4WD
I'll give all of those a try when I get a break in the weather. I appreciate your replies.
   / RK24 stuck in 4WD
I pushed snow with it yesterday. I tried all of your suggestions and nothing worked. I thought for sure getting the weight off the front end would.
   / RK24 stuck in 4WD #6
Wow, that is disappointing! That leads me to believe there is something in all the linkages bound up. I guess I'd be trying to follow your 4-wheel drive lever to see if there is something bound/frozen up.
When did this issue first happen?
Does your tractor stay outside? Is there a possibility ice snow got somewhere that froze?
   / RK24 stuck in 4WD #7
Has it got a loader? If just a year old, is it still under warranty? What does the owner's manual say about leaving it in 4wd all the time? For that matter, how do you know it is in 4wd instead of 2wd?
   / RK24 stuck in 4WD #8
My 40hp New Holland is sometimes difficult to get in or out of 4wd. If I pull hard or push hard on the lever - nada, I have to push or pull sharply. Kind of SNAP it in or out of 4wd.
   / RK24 stuck in 4WD #9
That could just be a sticky lever, or a sticky shifting collar in the transmission. It can also be caused by a 4wd with a mismatched front to rear tire ratio, although the OEM tires shouldn't do that.
   / RK24 stuck in 4WD #10
It's just a sticky mechanism. It's not that it takes a lot of force, but a steady pull is not as effective as a sharp pull/yank with no more force, Kind of like the difference between a tire wrench and an impact wrench.
2020 DRAGON ESP...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
3-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
3-Gang Reel Mower...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
