Kawasaki mule, dump bed question
/ Kawasaki mule, dump bed question #1
Harley Jim
2606H Massey Ferguson
Hello everyone,
I'm Jim, this is my first post.
I am restoring a 2004 kawasaki mule 550, and I want to add a linear actuator to make the box a dump bed, dose anyone know what the stroke length of the factory unit is. I have several here I can retro fit and not spend the $1,200 for an oem part. Thank you, Jim.
It's a bit rough now, but I have done a couple of them.
My last project, it was rougher than the Mule.
Thank you.
/ Kawasaki mule, dump bed question #2
See if you can source a parts diagram. Then call Kawasaki with the part number and ask them about the cylinder specifications.
/ Kawasaki mule, dump bed question #5
This is on a 2012 mule 4040
I have searched through my stock and the best fit I have is only a 10" stroke, so!
I'll just order one, it's still over $1000 dollars cheaper than the oem unit. I think 440lbs of lift should be enough for my use, if not I can add another to the right side and have dual cylinders. I'll just have to try and see!
Is there an intrest here for build threads?
Im going to do a little motor work, if it proves worthwhile, I want to do a total rebuild?
LOT OF TRANSPLANTER PARTS (A64278)
LOT OF...
Kubota L2501D 4x4 Utility Tractor with Land Pride 72in Brush Cutter (A64553)
Kubota L2501D 4x4...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
2022 EZ-GO ELITE...
2013 Ford Explorer SUV (A64557)
2013 Ford Explorer...
2022 EZ-GO ELITE...
