4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,080
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
The cylinder must extend to lift. It extends by pressurizing the non-rod end. It doesn't matter if the non-rod end is up or down.
And there are loaders with the lift cylinder rod end toward the bucket and loaders with it toward the cab.
You don't often see bucket cylinders with the rod end toward the cab, as that would expose hoses and seals to more damage.
Bruce
That’s more to do with removable vs permanently fixed loaders. The removable loaders have all the hoses going to a central block and the hoses are on the arms where a permanent mounted one has the hoses on the machine. The barrel needs to be mounted at the same side as the hoses so it’s not moving and chafing them.
