Increasing the lift capacity of a FEL
/ Increasing the lift capacity of a FEL #61
The cylinder must extend to lift. It extends by pressurizing the non-rod end. It doesn't matter if the non-rod end is up or down.
And there are loaders with the lift cylinder rod end toward the bucket and loaders with it toward the cab.
You don't often see bucket cylinders with the rod end toward the cab, as that would expose hoses and seals to more damage.
Bruce
That’s more to do with removable vs permanently fixed loaders. The removable loaders have all the hoses going to a central block and the hoses are on the arms where a permanent mounted one has the hoses on the machine. The barrel needs to be mounted at the same side as the hoses so it’s not moving and chafing them.
/ Increasing the lift capacity of a FEL #62
I have same tractor/loader. 8500lb with cast wheels and fluid.
Loader seems strong enough to me, pins in "power" position and only time it doesn't lift is when I have way too much in the bucket (wet mud or pen pack manure)
I haven't even driven my tractor since I posted this! I get limited time at the house and a lot is doing other stuff, trying to catch up on things that happen while I am out on the road.
David from jax
/ Increasing the lift capacity of a FEL #64
The rod side of the piston generates less force for the same pressure, due to the rod taking up some of the piston surface area. So, flipping end to end would make a substantial difference in lift capacity. That is why you don't see cylinders attached with the cylinder end at the bucket.
Makes no difference. Surprises me that people still think this.
As mentioned....regardless of orientation, the cylinder must EXTEND to raise the loader. Therefore the area of the rod has ZERO effect on its lift capacity in either orientation.
The manufactures decision on which way to orient is quite simply which end the hoses are fed from.
On removable loaders, like most modern loaders.....the supply lines run down the loader frame....there for we see the base of the cylinder attached to the loader frame....and the rod end pointing down. Because the base end/barrel of the cylinder doesnt move.
On older non-removable loaders....the hoses were usually fed from the tractor or the loader upright and not down the loader arm. As you can see in BCP's pictures. Its all about where the hoses are fed from
/ Increasing the lift capacity of a FEL #65
David from jax
Breaking down your loader.....the manual shows WAY more in-depth lift capacities than just a max height @ pin rating
I'll give you three numbers from the LA1153 manual.
The lift specs...IN POWER POSITION....and 800mm forward of the pin (~32")
Breakout (which is lift capacity at ground level) is 3415 lbs
Lift to 1500mm (~5') is 2646 lbs
To max height is 1830 lbs
Not to bore you with the physics....but your loader cylinders are mounted at an angle in relationship to the loader arms in which they are lifting. Gotta use some trig to calculate the upward force. Which is the Sine of the angle. If you look at your loader on the ground vs at full height....you can see that the angle of the cylinder changes in relationship to the loader arm. The angle gets smaller. And therefore the upward force also gets smaller.
Thats why the loader is almost twice as strong at its lowest point vs its highest point.
The higher you lift....the less capacity you have.
This is represented in the real world if you have ever lifted something heavy.....and are able to lift it to maybe 3-4' off the ground then it just wont go any higher.....Im sure many of us have been in that scenario before. Sometimes curling the load (which shifts the load CLOSER and therefor less leverage working against us) might allow it to be lifted a little higher)
But in the case of your loader.... It doesnt look like you are lifting more than 5' off the ground. And with pallet forks on....you should have a lift cap of the 2646 lbs or so @ 32" forward. Sure....what you were loading looks like its load center might be a bit more forward of that, but not by much. I'd certainly think your tractor should handle them with ease if they are ~2000lbs or so. Which leads me to assume you are either down a tad on pressure, cylinders getting a bit weak, or really underestimating the weight
/ Increasing the lift capacity of a FEL #66
May not be true in all cases. When posing the question to AI, this is the result:
"No, a double-acting hydraulic cylinder does not necessarily exert the same force in both directions, even though it can apply force in both directions; the force can be slightly different depending on the design due to the difference in piston area exposed to pressure when extending and retracting, which is related to the rod diameter.
Explanation:
  • Piston area difference:
    When extending, the hydraulic pressure acts on the full piston area, while when retracting, the pressure acts on a smaller area due to the piston rod taking up space in the cylinder.
  • Design considerations:
    While the difference in force may be minimal in well-designed cylinders, it's important to consider this factor when calculating the required force for an application.
Key points about double-acting cylinders:
  • Functionality: They can apply force both when extending and retracting the piston rod.
  • Application: Ideal for situations where precise control and movement in both directions are needed, like in machinery or construction equipment.
  • Hydraulic pressure: The force exerted by a double-acting cylinder is directly related to the applied hydraulic pressure and the piston area."
Here's why:
/ Increasing the lift capacity of a FEL #67
Explanation:
Here's why:
You are missing the fundamental point.
IT DONT MATTER WHICH WAY THE CYLINDER IS ORIENTED
It STILL EXTENDS to LIFT the loader
/ Increasing the lift capacity of a FEL #68
Bruce
Look at these pictures BCP posted.
It doesnt matter which way the cylinder is pointing
They are BOTH extending to raise the loader
/ Increasing the lift capacity of a FEL #69
Isn't breakout a function of bucket curl (measured with the standard bucket)?
Technically a point load is being lifted slightly, but as the name "breakout" shows, it's like me using a pry bar to dislodge a boulder - yes, I can dislodge a 500 pound boulder, but I'm sure not picking it up, and the loader cylinders aren't involved in breakout.
/ Increasing the lift capacity of a FEL #70
You are correct. I responded to your post by mistake.
Sorry.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2017 John Deere 6195R (A60462)
2017 John Deere...
PALADIN INDUSTRIAL SCREENER (A60736)
PALADIN INDUSTRIAL...
2011 Chevrolet Cruze Passenger Car, VIN # 1G1PK5S94B7295110 (A61165)
2011 Chevrolet...
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
Giyi PG72 QA 72" Grapple (A60463)
Giyi PG72 QA 72"...
