Increasing the lift capacity of a FEL
   / Increasing the lift capacity of a FEL #21
I wouldn't do the cyl swap. Def check pressures like several have noted, as that may get you more lift within the spec range of the loader. Your front axle will be the weak point for sure. And keep front tire pressure up when doing heavy lifts too as tire pressure directly relates to load carrying capacity of the tire. You don't want to pop a bead or something from overload. Check the sidewall for max pressure. This will likely be higher than what the manual says to use. Myself, I don't put them at absolute max but a few psi below that.
   / Increasing the lift capacity of a FEL #22
2,326 lbs lift (full at 500mm)
2,536 lbs lift (full at 500mm)
The items I have been picking up with a lot of difficulty are in the 1500 pound range, so I need to look at the pressures and go from there.
David from jax
With those ratings, I would think the relief Is set below spec. The above suggests that a 1500lb weight should be an Easy lift with the Full height @ 500mm listed.
Trying not to not to knock on Kubota, but it IS a 67 HP tractor, should have no problem with what you are lifting (under a ton.) Check those pressures, seems like that is the fix without resorting to what would terminate a warranty.
How much counterweight are you using?
Filled rear tires, and usually a semi-mount Bush Hog 3008 but this past week it has been with my homemade Dura'grader imitation. I haven't had issues with the rear end being light, EVER! So that is another reason I think my lift capacity is too low (which could be pressure). Messing with the pump or having a pair of cylinders made (or doing nothing at all) hasn't been decided yet. Most of the time I am only loading dirt, or moving stuff around or using the grapple. This past few weeks I have been picking up some heavy stuff, but in reality they were below rated capacity in pounds. The extension past the pin on the loader added tremendously to the load, but still...it was about 1500 pounds, so I felt like it should pick it up. A much smaller Kubota at the other end also had problems with picking them up and that owner felt like his 40hp tractor should do what mine did. I mean, they are both ORANGE aren't they?
David from jax
Loading these were the reason for the thoughts on increasing cylinder size. Front one is a complete unit, rear was missing transmission. The dump bed on front one is a lot heavier than the sheet metal framework that holds the tank. Both are now in TN being used as parts. Hydraulics on front unit will be coming back here in April on a cab unit I have in TN. Carb will be used on one here after it is rebuilt. The original came in a cardboard box with pieces missing!
David from jax
   / Increasing the lift capacity of a FEL #25
I have an M7040SUHD with an LA1153 loader. For all practical purposes, this loader does a fine job. Occasionally I need to lift something that is closer to the max limits of the loader, and the lift cylinders just won't pick it up. Most of the time, I figure it is the distance from the pin, since the loader is rated at 24" from pin. Push it either further out, or push it right up against it's RATED limits, and it just won't do it. I can usually compensate by using the curl, but sometimes that isn't enough.
A friend has the same issues, and we talked about putting larger cylinders on the loader. My clinders "may" fit his smaller loader, so we could go together and just buy one set for my tractor. Another option is for me to buy a set and keep my originals in case the new ones have issues. A local hydraulic shop can be tasked into making new cylinders to fit, somewhere in the range of 1/4 to 1/2" larger in diameter. I am considering 1/4" larger, because I know me, and if I need to pick up something, I am probably going to push the limits right up to the max. 1/2" might be just enough to do the FEL frame in, so I am going to be a little more conservative.
Has anyone ever increased the size of their loader cylinders, and what was the outcome? Was it worth the expense, and just how much did it slow the hydraulics down as far as normal useage?
This is pretty much a pipe dream right now, but we are going to look into it, unless someone has already done it and can explain why we shouldn't.
David from jax
A larger cylinder would exert more force but I would bet you would quickly run into clearance issues. I would verify relief pressures first. I recently got around to repacking my tilt cylinders. I had a laugh because through the years I had gotten accustomed to the loss of power. Imagine my shock when it killed my tractor before it went over relief. Check your relief pressures.
   / Increasing the lift capacity of a FEL #26
adjusting the relief vale is not actually playing with the pump and is actually quite simple once you know where the part is. I changed the poppet and seat on mine, chasing the upper limit of the spec but apparently my tractors pump is no longer able to give the max spec for my tractor. it was much cheaper to test if the relief valve was leaking than to dive in and replace the pump. adding shims no longer raises the pressure so I'm living with a slightly reduced lift capacity. Don't play with the shims unless you have a gauge to test the pressure after.
going into relief should not kill the engine. not sure what is going on there but it shouldn't be killing the engine.
   / Increasing the lift capacity of a FEL #27
I had the same machine and I regularly picked up 2 1100# round bales from max height, also had a pretty big grapple for it and lifted 30”+ green fir logs. With cast weights in the rims and a 7’ blade on the back I often drove around with the rear wheels in the air when moving logs and stumps. Never felt the loader under performed and I tend to push my equipment to the limit. The first thing I would do is check your pressure.
   / Increasing the lift capacity of a FEL #28
The heaviest thing I regularly carry on my FEL is a 2K# counterweight. I can lift it with the bucket but I have very little weight left on the rear tires of my 2WD tractor. It's dangerous as hell especially on unlevel terrain. When I have to move it, I use a chain to connect it directly to the quick attach frame. This moves the load rearward about 2 ft and makes a big difference in stability/lift capacity. If you have a quick attach, you can also drop the bucket for more capacity.
   / Increasing the lift capacity of a FEL #29
Yep, I had to stop over loading my tractor and just switch to my backhoes FEL unloading a 3400lb pallet of quikcrete, was able to get it moved to the back of the trucks bed with the tractor but only had a post hole digger on the 3 point. Had to put it in 4 wheel to move the pallet back because the rear tires were spinning.
Even with chain on Forks added to the bucket it was an easy lift for the TLB's FEL.
(that was dumb), I should have started with the industrial FEL to begin with, but wanted and now know using a "known" weight ~ how much is over the FEL's ability to lift out of the pickup's bed.
   / Increasing the lift capacity of a FEL #30
It has bern several tears ago now (early days of supply issues of covid) so provably early 2020, my son was shopping for a tractor. Part of his needs was to be able to lift a certain amount if weight lifted with forks. Within a few days if receipt of his tractor, he attempted to lift the item for the first time. The new tractor that was purchased in part to lift this item would not lift it. He called his salesperson, not happy, after a bit, the service department head called my son and explained to him how to increase the hydraulic flow to gain the additional lifting capacity.
Perhaps something similar could be done fir your tractor.
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2020 CAT 308 (A53317)
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
