Looking for LED lights to replace older 3x5 or 4x6 halogens
   / Looking for LED lights to replace older 3x5 or 4x6 halogens
Another question - has anybody run across these with a built-in switch?
My question as well. On my old halogen lights I took it apart, drilled a hole in the case and put in a waterproof on-off switch. The LED's I'm no looking at have a pigtail out the back so I wonder in an inline thumb "rocker" switch is a better idea.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #13
Buying them from Amascon will always be a crapshoot, no matter what. You don't know if they are of good quality and returning defective ones dealing with Amascon will always be a crapshoot.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #14
These have a bit smaller current draw
I've had good luck with the LED lights I've purchased from Amazon
Agreed. I bought a Makita impact gun advertised as new in the box but it came through in a ripped open opened box and returned box. I returned it. Next up a vacuum and obviously used and no box. Sent it back as well. I forgot over a few months and then bought an expensive flashlight. Opened, used and returned. Back it goes.
I'm done with that type of stuff from Amazon. I can buy the same things local for a few $$ more--but no hassle--and help those guys. There's also Lowes and Home Depot mail order that delivers free right to my door. No muss, no fuss and I get what I want.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #16
Amascon does have a interesting return policy... You return something and then they resell it to an unsuspecting customer. Not something I consider an up front and honest business policy.
Had that happen as well and returned the return item. They probably passed it on to another customer, I don't doubt that one bit actually.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #17
I am going to replace the whole housing. I can't see the amp draw listed on any of the lights. My fuse for the lights I'm changing is 10 amp so I need to keep it under that. Where do I find this or how is it computed. I know draw is low on LED.
Amperage‎6.67 Amps
Look at the › See more product details
Watts divided by Voltage. 80w/12 volts= 6.67 amps
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #18
Never had a problem returning anything on amazon. I have also had the cheapest LED pod lights I could find on there for 6yrs. I believe they where $23 a pair.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #19
Actually, this is interesting for those of us who use Amazon for farm stuff. For the original poster, I have wired several tractors and my RTV with add-on LED bars and pod lights from NiLights bought off of Amazon. No problems after a couple of years of use - buy their lights and paddle switches and use my own fuse blocks and feeder wiring harnesses (but their harnesses are sometimes plenty long enough). Make sure I use a heavy enough ground wire source to support the lights.
So...my experience, no problems. But a Harbor Freight light bar has done fine as well...
I also order a lot of Amazon stuff for the farm, from small parts to Hydraulic cylinders, Shell Rotella oil, starter for the Kubota RTV, Lucas grease, Stanadyne additives, etc, etc. Well, you get the idea. For years and years. I don't seem to have problems. But 5030's experience has been a lot different than mine. Don't know if area makes a difference - I'm in Kentucky.
I do try to choose a vendor that's "fulfilled by Amazon," and has a good rating. If only a few ratings, or a low rating, I choose a different vendor. Maybe that explains part of this. (Amazon has a review rating function now, which isn't perfect, but seems somewhat helpful).
What about others here? Having any patterns of problems with Amazon? Just curious.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #20
Tiger Lights offers direct replacement LED lights for many applications:
A bit pricey but most are plug & play which saves a lot of time doing the swap.
2020 DRAGON ESP...
Club Car Utility Cart (A55853)
Club Car Utility...
2018 Chevrolet Silverado 2500HD Crew Cab Service Truck (A56858)
2018 Chevrolet...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2007 Yamaha Rhino 660 (A56435)
2007 Yamaha Rhino...
Armstrong 64-405A Torque Wrench (A59076)
Armstrong 64-405A...
