Looking for LED lights to replace older 3x5 or 4x6 halogens
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Where can I get some LED lights to replace the 4"x6" halogens that are in common use for worklights on equipment? I can't seem to find any that size.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #3
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #4
Replace the whole housing. It's cheaper than even buying a glass bulb now.
I am going to replace the whole housing. I can't see the amp draw listed on any of the lights. My fuse for the lights I'm changing is 10 amp so I need to keep it under that. Where do I find this or how is it computed. I know draw is low on LED.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #8
Amps = Watts divided by Volts. While it may be 12v system, the actual battery voltage would about 12.6v not running and 13.9v while running.
Edit: Forgot to mention--The fuse is there to protect the wiring. Increasing its value to gain a little extra current is a bad idea. If you need more current (amps) run a separate circuit with larger wire.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #9
Another question - has anybody run across these with a built-in switch?
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #10
The Amazon ones are rated at 71 watts - about 5.5 amps @ 13VDC. LED's are a constant draw - current does not go up with voltage unless it has a poorly designed current limiter. The fuse is usually there to protect the equipment - #14 wire can handle 20A without any trouble. The heavier gauge is used for physical strength.
2016 Freightliner M2 106 Terex Hi-Ranger HRX55 55ft. Insulated Bucket Truck (A55973)
2016 Freightliner...
DMD 3PT DISC MOWER (A52708)
DMD 3PT DISC MOWER...
2014 JLG 6042 TELESCOPIC FORKLIFT (A52709)
2014 JLG 6042...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
