Looking for LED lights to replace older 3x5 or 4x6 halogens
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Where can I get some LED lights to replace the 4"x6" halogens that are in common use for worklights on equipment? I can't seem to find any that size.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #3
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #4
Replace the whole housing. It's cheaper than even buying a glass bulb now.
I am going to replace the whole housing. I can't see the amp draw listed on any of the lights. My fuse for the lights I'm changing is 10 amp so I need to keep it under that. Where do I find this or how is it computed. I know draw is low on LED.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #8
Amps = Watts divided by Volts. While it may be 12v system, the actual battery voltage would about 12.6v not running and 13.9v while running.
Edit: Forgot to mention--The fuse is there to protect the wiring. Increasing its value to gain a little extra current is a bad idea. If you need more current (amps) run a separate circuit with larger wire.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #9
Another question - has anybody run across these with a built-in switch?
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #10
The Amazon ones are rated at 71 watts - about 5.5 amps @ 13VDC. LED's are a constant draw - current does not go up with voltage unless it has a poorly designed current limiter. The fuse is usually there to protect the equipment - #14 wire can handle 20A without any trouble. The heavier gauge is used for physical strength.
JOHN DEERE BWA 28 BLADE DISC HARROW (A52708)
JOHN DEERE BWA 28...
PALLET TOTE OF CERAMIC TILES (A58374)
PALLET TOTE OF...
. T/A TRASH TRAILER (A58216)
. T/A TRASH...
2019 Toro Z Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2019 Toro Z Master...
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A56858)
2013 Ford F-550...
