Looking for LED lights to replace older 3x5 or 4x6 halogens
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Where can I get some LED lights to replace the 4"x6" halogens that are in common use for worklights on equipment? I can't seem to find any that size.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #3
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #4
Replace the whole housing. It's cheaper than even buying a glass bulb now.
I am going to replace the whole housing. I can't see the amp draw listed on any of the lights. My fuse for the lights I'm changing is 10 amp so I need to keep it under that. Where do I find this or how is it computed. I know draw is low on LED.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #8
Amps = Watts divided by Volts. While it may be 12v system, the actual battery voltage would about 12.6v not running and 13.9v while running.
Edit: Forgot to mention--The fuse is there to protect the wiring. Increasing its value to gain a little extra current is a bad idea. If you need more current (amps) run a separate circuit with larger wire.
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #9
Another question - has anybody run across these with a built-in switch?
   / Looking for LED lights to replace older 3x5 or 4x6 halogens #10
The Amazon ones are rated at 71 watts - about 5.5 amps @ 13VDC. LED's are a constant draw - current does not go up with voltage unless it has a poorly designed current limiter. The fuse is usually there to protect the equipment - #14 wire can handle 20A without any trouble. The heavier gauge is used for physical strength.
1999 Eagle Road Tractor (A55272)
1999 Eagle Road...
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
SOFTSTART W/ ACROSS LINE BY-PASS STARTER (A58374)
SOFTSTART W/...
2019 Ford F-250 4x4 Crew Cab Roya Service Truck (A55973)
2019 Ford F-250...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
