brewdog
Gold Member
- Joined
- Dec 4, 2005
- Messages
- 485
- Location
- NW PA
- Tractor
- LS MT 225s, New Holland 3040, Kubota Z 422 - 60"
Update. Painted the elevator and added a cycle counter. Bought the 120v counter on amazon and added it to the control box. The limit switch is mounted in the UP limit position so it only counts a full lift one time. Fun little project that works good.
Been working on a Lift Elevator for the Pole Barn. I decided to build a hoist type lift. I tried the Unistrut and wheels you find on Amazon and they didn't work very well. Any off balance loading on the platform created binding and a dangerous situation so I removed all the welds and rebuilt it using my own rail and wheel designs. The main loading wheels are 4"o.d.x 2” wide steel wheels with roller bearings. The axle mount is 1.5” DOM Tubing with a 1” shaft turned down to a 3/4” axle for the roller bearings to ride on. The side to side stabilizing wheels are 3-1/2” x 1.25” wide steel wheels with a 1/2” grade 8 bolt used for the axle. I added two fall protection devices one on each side for additional safety. The vertical rails I made from 12’ long sections of 3/16” x 2” x 3” angle iron welded to a 1/8" x 2"x2" square tubing vertical section. The platform is 1/8”x 2”x2” square tubing and 1/8”x2” Angle iron. The round lifting arm is 2.5" sch 80 pipe. I used 1/4” x 2” flat plate for anchoring to the concrete and beam structures. 1/2” wedge bolts went in the cement. The hoist is rated at 2200 lbs with the roller block tied to the lifting sch-80 pipe. I bought a new roller block unit at Harbor Freight rated for 2 tons. Tested the elevator out with 800 lbs the other day! Ran great. That’s 300 lbs more than I will ever put on it. It makes a nice work bench when it’s not being used. The new design has zero side loading issues. I can stand 100% on either outside edge and it goes up smooth. Here's a load of wood on it for the loft railings. If it stays warm enough I'll finish painting it after the railings are finished.
