Elevator for Pole Barn - updated photos with cycle counter
   / Elevator for Pole Barn - updated photos with cycle counter #11
Looks nice and robust. Metal channel must have cost a bit but, from the pics, it'll probably outlive you
   / Elevator for Pole Barn - updated photos with cycle counter #12
I decided to upgrade the control system on my Pole Barn Loft Elevator. I put two fixed pushbutton stations on the upper and lower levels. A third pushbutton station is movable and travels with the elevator. I purchased the parts on Amazon and built the controller. Here's some pictures. Forgot to mention that I added an additional Low Level Limit switch to maintain some tension on the spool and cable. This feature keeps the steel cable from unravelling on the spool and making a mess. Never use a winch for a hoist application. The hoist has a built in locking feature to prevent free spooling and accidental load dropping.
Great clean & clever build! I may use a couple of your ideas on my next project.
I did something similar a few years back just prior to hip surgery. I made a deck elevator out of an old unused Genie Manlift. I posted this in another thread but it seems appropriate to re-post here:
The lift required extensive modification, but could still be re assembled if necessary to use as originally designed.
The trap door in the deck was a bit tricky. I looked at pneumatic, electric and hydraulic cylinders, but most were too slow. I finally used a series of weights & pulleys so the lift itself would raise & lower the trap.
It came in very handy after surgery and continues to be useful for lifting items up to the second floor. My only regret was not using a bigger platform.
Tony H, I bought the steel from a steel distributor so the price wasn't so bad. Buying full length sections of 20' and 24' left me some extra pieces to use on other projects. It will definitely outlive me.
View attachment 2410450 View attachment 2410452
View attachment 2410443 View attachment 2410444
View attachment 2410445 View attachment 2410446
Thanks. Great idea using the Genie lift and you did a nice job on the build.
Weather warmed up enough to finish painting the Elevator Lift. It's been a handy device and has helped me organize the Pole Barn.
   / Elevator for Pole Barn - updated photos with cycle counter #16
Just sold my 'Hammerblow' bale elevator to a guy down the road as I have no use for it anymore. 30 feet long but could be shortened or lenghtened if required. We live in a ranch style one level house so no elevator required and I dislike steps anyway. Human elevator not in my cards at all.
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
