Mulcher for sagebrush on rocky ground?
/ Mulcher for sagebrush on rocky ground? #1
Sierraau
Truckee, CA
2019 Rx7320
I've got a Kioti 7320 and I am looking for some sort of mulcher that can operate in rocky ground. I have a bunch of sagebrush on my property that is 3" high and pretty thick- too thick to see any underlying rocks up to 2' tall. Do anyone have any recommendations on what I can use to clear the land without destroying both the tractor or the attachment? I do have a 10' wide mower with two heads, but I took it out last fall in in just a few minutes I hit my first rock that dinged up one of the blades pretty good. Not a long term solution for sure. Also so how would the mulcher handle thick ponderosa pine needles?
/ Mulcher for sagebrush on rocky ground? #2
Rocks and cutters simply don’t work well together. A forestry masticator on a skid steer or excavator would work better, but large rocks would put those out of commission when the chipper teeth start breaking. With that size rocks, a small dozer with the blade held several inches above the ground would be the best option. After removing the bulk of the sage and maybe some rocks by pushing into piles or windrows, you might be able to use the cutter to finish the job and maintain the area.
/ Mulcher for sagebrush on rocky ground? #3
Rent one of these
/ Mulcher for sagebrush on rocky ground? #4
I have a couple areas on my property with sage brush. I guess I'm just lucky. I don't have a rotary cutter, of any type, to bust up. I sure do have the rocks though.
My solution is not quick - is not easy - however, it is permanent. With my light Stihl chain saw - cut down the sage at ground level. With the grapple on the tractor - pick and pile the surface rocks.
Then - put the Wally on the 3-point. Go back and chip all the sage.
An appropriate chemical sprayed on the sage stumps will - mostly - end this problem.
I spent the better part of three summers clearing and making a two acre meadow. I ended up using a rototiller and planting it back to native wildflowers.
One hell of a lot of work to make the birds and bees happy. However - it is very pretty and colorful in the spring and early summer.
/ Mulcher for sagebrush on rocky ground? #5
If the sagebrush is only 3" high and the rocks are 2' tall, removing the rocks may be the priority.
/ Mulcher for sagebrush on rocky ground? #6
Similar problems here. We modified an old BH, cut the blades down and added hardened 3/8 chain. It's been working like a charm. While I try to avoid the rocks, hitting them does not hurt the chains like it did the sharpened blades.
/ Mulcher for sagebrush on rocky ground? #7
Fire.
That is the best way to remove sage brush. It's too bad you are where you are, that kind of prevents that.
If you want to tear equipment up, than go for it. Otherwise, manual removal is the second most cost effective way. It is obviously not the best at time efficiency.
We burn them here in Wyoming.
/ Mulcher for sagebrush on rocky ground? #9
Weed wacker with saw blade?
/ Mulcher for sagebrush on rocky ground? #10
To be clear, a 2 ft tall rock is going to damage or tip your tractor over. These need to be located and marked with a stake or something before you try anything. Backing in a little at a time may be one approach. In any case there is going to be some handwork required to make this a mowable parcel. I recently reclaimed the neighbors 5 ac field that was covered in scattered rocks up to 12" diameter and growth 5ft tall. The first mowing cost me a set of hammers for the flail. $400. The I disced and cleared the rock and afterwards I modified the mower shown above. Now I keep it mowed and he pays annually.
Some of the surface rock removed.
WATER TRAILER (A58214)
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2012 HINO 268A 4X2  26FT NON CDL BOX TRUCK (A59906)
2012 HINO 268A 4X2...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61307)
2021 Gehl RT215...
2011 CHEVROLET AEV 11WC TYPE 111 AMBULANCE (A59823)
2011 CHEVROLET AEV...
2016 MACK CXU613 (A60736)
2016 MACK CXU613...
