97 John Deere 425 steering cylinder
   / 97 John Deere 425 steering cylinder #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Is there a good video on how to change out the steering cylinder on my 425? I looked on you tube and couldn't find much. Or maybe some one can explain it to me simply?
   / 97 John Deere 425 steering cylinder #2
How much of it are you changing out? Looks pretty straight forward to remove it but must be something not apparent to you. What might it be?
A photo and some arrows will help us help you out.
Well my mower deck is still on is that in the way? Do I need to remove the front wheels? Also do I need a certain numbered cyl for this 425?
How do I find out if my 425 is an A or C etc. for fitment of the cylinder?
   / 97 John Deere 425 steering cylinder #5
It can be done with the deck installed. Does your tractor have a triangular steering plate in the center and 2 shorter tie rods? If so it’s the earlier version. The later revision has a single long tie rod.
I will have to look I can't send pics don't know how maybe you might have one to post on here?
   / 97 John Deere 425 steering cylinder #7
I’m not sure. I do it from my phone.
No it is not all wheel steer and I do not have a manual the serial # is missing there is some numbers on the radiator would that be the number I'm looking for? I don't believe it has a triangler plate it must be the newer model.
Here are the numbers I found on the radiator. TCD P/N 04-0034 JD P/N AM 121497 Mfg date 1-7-97
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
2014 CAT 140M2 MOTORGRADER (A50854)
2014 CAT 140M2...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2015 DODGE RAM...
2012 GENIE GTH1056 TELEHANDLER (A50854)
2012 GENIE GTH1056...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
