97 John Deere 425 steering cylinder
   / 97 John Deere 425 steering cylinder #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Is there a good video on how to change out the steering cylinder on my 425? I looked on you tube and couldn't find much. Or maybe some one can explain it to me simply?
   / 97 John Deere 425 steering cylinder #2
How much of it are you changing out? Looks pretty straight forward to remove it but must be something not apparent to you. What might it be?
A photo and some arrows will help us help you out.
Well my mower deck is still on is that in the way? Do I need to remove the front wheels? Also do I need a certain numbered cyl for this 425?
How do I find out if my 425 is an A or C etc. for fitment of the cylinder?
   / 97 John Deere 425 steering cylinder #5
It can be done with the deck installed. Does your tractor have a triangular steering plate in the center and 2 shorter tie rods? If so it’s the earlier version. The later revision has a single long tie rod.
I will have to look I can't send pics don't know how maybe you might have one to post on here?
   / 97 John Deere 425 steering cylinder #7
I’m not sure. I do it from my phone.
No it is not all wheel steer and I do not have a manual the serial # is missing there is some numbers on the radiator would that be the number I'm looking for? I don't believe it has a triangler plate it must be the newer model.
Here are the numbers I found on the radiator. TCD P/N 04-0034 JD P/N AM 121497 Mfg date 1-7-97
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
1273 (A50490)
1273 (A50490)
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
TMA (A49461)
TMA (A49461)
2010 GMC Acadia SUV (A50324)
2010 GMC Acadia...
