97 John Deere 425 steering cylinder
   / 97 John Deere 425 steering cylinder #11
And you couldn't match up the different cylinders shown in the JD parts link to tell which one needed?
I think it looks like the 12C AM147176 and if it is this is the right number to order?
Here are the numbers I found on the radiator. TCD P/N 04-0034 JD P/N AM 121497 Mfg date 1-7-97
Ok I think it is
Where is a good place to get one and not break the bank?
   / 97 John Deere 425 steering cylinder #14
Any idea what failed? Or it just quit working? Are you certain it just needs a cylinder?
It leaks must be worn out seals. Still works just leaks really bad. Man, those are expensive, and I've seen where you can't just replace the seals. Where to get one fairly cheap?
   / 97 John Deere 425 steering cylinder #18
The Amazon ones actually work OK. The cylinder can be resealed as well, but it takes some pretty involved cutting and welding.
Well my cutting and welding abilities are not very good anymore I just want a good cyl to replace the old leaky one I'm tired of putting cardboard down on my garage floor
   / 97 John Deere 425 steering cylinder #20
How did replacing the cylinder work out for you?
I replace a leaky steering cylinder on my JD430 late last fall with aftermarket one and it works well & the fit was good, but we will see in couple of years how well it survives real use?
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
Kubota ZG327 (A50120)
377789 (A51573)
377789 (A51573)
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
