Need heavier hydraulic top and side link suggestions JD 6120M
/ Need heavier hydraulic top and side link suggestions JD 6120M #1
Dadnatron
Versailles, KY
JD 5100e with FEL
Looking for a pretty beefy hydraulic top and sidelink for JD 6120M.
Rear lift is around 5500lbs and I want to ensure the links handle that weight easily. Need to feather out my land plane better, but want it to be able to handle anything else for the machine. I’d also like to have it spec’d with internal flow preventor to keep it locked under pressure of the implement.
I have 3 rear hydraulics, so want to put the links on one with an electronic selector so I can keep it hooked up and usable. I had them on a previous machine and was constantly removing the hoses to attach other things. I’d like to avoid that and keep 2 connections open for other use.
So if anyone has any recommendations or connections for heavier duty links and selector switches, I’d appreciate it.
/ Need heavier hydraulic top and side link suggestions JD 6120M #2
Contact FitRiteHydraulics He will build what you need
gg
Thanks, I thought he’d stopped at some point. I had him do the same on my previous tractor, but forgot the name.
/ Need heavier hydraulic top and side link suggestions JD 6120M #4
You are looking at about $3K for everything. Cylinders will dead lift just over 11,000lbs for your tractor.
Do you have the measurements for a 6120M?
It’s not currently on your list.
/ Need heavier hydraulic top and side link suggestions JD 6120M #6
I do, just not a common machine to build for. It's been a few years since I have built a set for this model.
I'm assuming that yours is a cat 2 hitch?
Need to fill out the Fit Rite contact page.
/ Need heavier hydraulic top and side link suggestions JD 6120M #7
Which electronic selector are you planning?
I haven’t delved to deeply into options, just know that I definitely want one.
Any recommendations?
/ Need heavier hydraulic top and side link suggestions JD 6120M #10
I have one that you have to hold a button down to divert to the second output, I don’t like it because you have to hold it down instead of toggling a switch. I was hoping you were going to tell me about an awesome one I can switch to.
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
John Deere 5075E (A53317)
John Deere 5075E...
1005 (A61166)
1005 (A61166)
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
Bobcat S740 (A57148)
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
