Need heavier hydraulic top and side link suggestions JD 6120M
/ Need heavier hydraulic top and side link suggestions JD 6120M #1
Dadnatron
Versailles, KY
JD 5100e with FEL
Looking for a pretty beefy hydraulic top and sidelink for JD 6120M.
Rear lift is around 5500lbs and I want to ensure the links handle that weight easily. Need to feather out my land plane better, but want it to be able to handle anything else for the machine. I’d also like to have it spec’d with internal flow preventor to keep it locked under pressure of the implement.
I have 3 rear hydraulics, so want to put the links on one with an electronic selector so I can keep it hooked up and usable. I had them on a previous machine and was constantly removing the hoses to attach other things. I’d like to avoid that and keep 2 connections open for other use.
So if anyone has any recommendations or connections for heavier duty links and selector switches, I’d appreciate it.
/ Need heavier hydraulic top and side link suggestions JD 6120M #2
Contact FitRiteHydraulics He will build what you need
gg
Thanks, I thought he’d stopped at some point. I had him do the same on my previous tractor, but forgot the name.
/ Need heavier hydraulic top and side link suggestions JD 6120M #4
You are looking at about $3K for everything. Cylinders will dead lift just over 11,000lbs for your tractor.
Do you have the measurements for a 6120M?
It’s not currently on your list.
/ Need heavier hydraulic top and side link suggestions JD 6120M #6
I do, just not a common machine to build for. It's been a few years since I have built a set for this model.
I'm assuming that yours is a cat 2 hitch?
Need to fill out the Fit Rite contact page.
/ Need heavier hydraulic top and side link suggestions JD 6120M #7
Which electronic selector are you planning?
I haven’t delved to deeply into options, just know that I definitely want one.
Any recommendations?
/ Need heavier hydraulic top and side link suggestions JD 6120M #10
I have one that you have to hold a button down to divert to the second output, I don’t like it because you have to hold it down instead of toggling a switch. I was hoping you were going to tell me about an awesome one I can switch to.
/ Need heavier hydraulic top and side link suggestions JD 6120M #11
If you think that you want a particular function to remain on instead of auto returning to the default position, simply install a maintained switch instead of the momentary switch that you have.
The idea of having the momentary switches is so that everytime you go to use that function, you always know where you are starting from. With a maintained switch, it's always a guess unless you have other ways of identifying what diverter is on.
It's not like you have to hold the switch on for minutes, typically only seconds.
But then I suppose it depends on what exactly you are using the divertered funtion for. :unsure:
/ Need heavier hydraulic top and side link suggestions JD 6120M #12
That’s a good point I can just swap out the electrical switch. I had the diverter for my snowblower wings. I replaced my with a tee fitting so both wings operate together and it’s a much better experience. It was super awkward to control them independently with the momentary switch.
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2014 American Signal Solar Towable Message Board (A59228)
2014 American...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED SDLANCH SDLD25 MOBILE HYD DUMPER (A60430)
UNUSED SDLANCH...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
209275 (A59823)
209275 (A59823)
