Potable air compressor you should have.....
/ Potable air compressor you should have..... #1
jkk04
Gold Member
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
Modern technology is amazing and makes life so easy.
/ Potable air compressor you should have..... #2
Looks basically worthless to me. Miniscule air delivery and it's plastic to boot. Real air compressors are made from metal.
/ Potable air compressor you should have..... #3
Wont work on my work trucks, unless i have loads of time. I carry a Dewalt 20v cordless compressor on my work rig already…..that airs up a tire pretty fast. But it is amazing the things there coming up with.
That was exactly what I thought first but it works for me so well...
especially on riding mower tires and compact tractor tires.
Jkk
/ Potable air compressor you should have..... #5
All I have is large tires and I don't want to spend all day filling them either. Even my little pancake compressor is huge compared to that.
/ Potable air compressor you should have..... #6
Those are not really made for large tires. I tried using a Kobalt one for larger tires (Car). It worked for about a year of about 15 or so tire top offs and then died. I got another one but only use it on bikes, mowers, dolly, and other small tires. It is great for that.
/ Potable air compressor you should have..... #7
I have the 60 volt DeWalt battery powered air compressor. I bought it when that's all they were selling at my local store. I wish I had the 20 volt because I have several batteries, but I only have 1 60 volt battery, but it still works, I just have to be sure the battery is charged up. I had bought a larger 60 volt battery and it died in fairly short time, and I will probably buy a 20 volt compressor before I buy another 60 volt battery.
/ Potable air compressor you should have..... #8
I have one of these RIGID tire inflators, had it for a couple years and use it all the time because my tractor tire has a slow leak. Works great!
/ Potable air compressor you should have..... #9
I thought the 60v one worked on either the 60 or the 20v battery? I got the one that only works on 20v as i have 10 of these batteries already.
/ Potable air compressor you should have..... #10
DeWalt batteries seem to be coming down in price. I just bought a pair of genuine 6 aH batteries for $100 delivered.
/ Potable air compressor you should have..... #11
I got the same thing at home depot last month. $100 for 2 x 6.0 ah dewalt batteries. I dont trust amazon or ebay batteries…. Too many after market fake batteries on those sites,
/ Potable air compressor you should have..... #12
A small inflator is nice. I bought the Airmoto off Amazon. For small tires such as the Kawasaki Mule or the dolly to move boxes around it is much quicker and easier than firing up a compressor and dragging out air hoses. It is also nice to toss in the glove box for road trips, charges off the USB port if needed. I have the Dewalt 20V inflator as well for vehicle and trailer tires. It and a 20V Dewalt impact stays in the truck and goes with me on trailer trips.
/ Potable air compressor you should have..... #13
I have not used mine on my tractor but it airs (tops off) up car tires just fine. It works for mowers and wheelbarrows too.
I may get one for each car.
/ Potable air compressor you should have..... #14
I wondered what a potable item was used for and thought maybe it was used in the bathroom. I think I would be disappointed with it since I'm used to using my 20 gal. compressor in my shop.
/ Potable air compressor you should have..... #15
What I have. VIAIR 88P.
/ Potable air compressor you should have..... #16
So, my buddy has one, and said it's good for one tire per charge.
/ Potable air compressor you should have..... #17
My work truck has it's own air compressor, so if one of the 18 large tires needs air... all I used to have to worry about was if the hose I had would be long enough! Nowadays, the trailers are almost all "auto inflate" systems, so all I have to worry about is the truck tires! Makes a guy lazy!
David from jax
/ Potable air compressor you should have..... #18
There are appropriate needs for these things. My daughter is bad about taking care of her car, but it does have a low pressure warning light. I bought her one of those compressors so she wouldn't wait to take it to the station and spend a couple of dollars every time a tire was low. The first one I bought her lasted 4 or 5 years and I just got her a replacement. I've thought about getting one for our car that doesn't have a spare tire.
/ Potable air compressor you should have..... #19
I don't know what is worse, people not maintaining their tractors in a timely manner or not maintaining their compressors in a timely manner. My compressors are all on a service schedule and all have timed condensate drains as well (except the little one). Not draining condensate in a receiver will eventually cause failure due to internal corrosion, sometimes with real bad results as a pressurized receiver is a bomb when it fails.
Besides, commercial sized compressors aren't a cheap date to begin with and they all produce condensation as part of their operating characteristics.
My Quincy QP retails for north of 6 grand and the Sulaire set me back almost 10 grand. Of course both have 440-3 motors.
/ Potable air compressor you should have..... #20
I just bought a Makita twin tank compressor. Replaced a Sears that lasted 40 years.
I've found an easy answer to carrying some type of cordless air compressor - routine maintenance. Sixty years of driving - NEVER had a flat tire.
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A69167)
2014 INTERNATIONAL...
Generac SD135 136kVA Standby Diesel Generator (A66734)
Generac SD135...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2018 Ford F-150 Ext. Cab Pickup Truck (A66736)
2018 Ford F-150...
2007 JOHN DEERE 120C EXAVATOR (A65056)
2007 JOHN DEERE...
UNKONW  TRIAXLE ALUMINUM VACUUM TRAILER (A67714)
UNKONW TRIAXLE...
