10kW Ground Mounted Solar Panel System
/ 10kW Ground Mounted Solar Panel System #21
The economics of solar varies tremendously from state to state. The big things to look out for are your state's policies on net metering, whether it's allowed and what rate they pay you for power returned to the grid. In some states there are additional incentives like Solar Renewable Energy Credits (SREC's) and even direct subsidies.
There's also a federal tax credit.
All I can say is it cost more than I thought it would going in. I wanted this for power outage back up and to knock down our monthly bill overall, Would I recommend it as a money saver out of the gate? Heck No, but our power rate is only $.08- $ .10 per KWH. Some of the states where power can cost a lot during certain hours a hybrid with solar and batteries might make a LOT more sense.
/ 10kW Ground Mounted Solar Panel System #22
All I can say is it will cost more than a person thinks going in, if DIY. I wanted this for power outage back up and to knock down our monthly bill overall, Would I recommend it as a money saver out of the gate? Heck No, but our power base rate is $.08- $ .10 per KWH.
And where I am we have generous net metering and expensive electricity and solar pays for itself in a few years even if you pay to have it installed.
/ 10kW Ground Mounted Solar Panel System #23
A complete solar installation paying for itself in the northeast, in just a few years, would be amazing
/ 10kW Ground Mounted Solar Panel System #24
I paid under $3/Watt for my system, installed. With the 35% federal tax credit it was under $2/Watt. I get the equivalent of about a thousand hours a year of full production, or about 1kWh per year for each installed Watt. Electricity here is $0.29 per kWh. Payback time is about six years.
That's assuming electricity stays at the same price, it's gone up 10% in the past year.
/ 10kW Ground Mounted Solar Panel System #25
Ok, 6 years. I read “a few”, which I took as 3, which would be amazing 😁
/ 10kW Ground Mounted Solar Panel System #26
I was inspired by this to go look at my actual production. I have a 10 kW system, trailing twelve months production is 12,000 kWh. So actually about 1200 hours equivalent a year. That's worth $3480 at current rates. I get 100% net metering at full retail rates so I get the full value.
And this is tax free income. If I were paying the electric bill I'd be paying with after-tax dollars.
/ 10kW Ground Mounted Solar Panel System #27
Google has a tool to calculate the payback of a solar system. I ran their model for our place in Oregon and it said that solar would cost us $8k over 20 years- there's never a payback. Then I noticed the small print that they assumed rates would go up 2.2% per year. Well in 2023 it went up 21%, in 2024 11%, and they're asking for 26% for 2025. If the state PUC keeps approving those increases, a solar system would end up costing less.
Price wise, I am able to get 23 bifacial solar panels (750w) and the mounting brackets for $2k delivered from my Chinese contact. Panels have a 25 year warranty and are rated\tested
So bifacial panels will break more easily in hail than standard panels?
/ 10kW Ground Mounted Solar Panel System #29
Edit:
Yes, some mixed test results but correcting my post in general front and rear sided glass panels break more often as a Group:
ps. One heck of a short time deal on Schneider XW 6848 Pro LF Inverters, basically less than 1/2 price.
Old reliable non HF inverter tech. If I had not already bought the EG 4 18K PV, I would buy 2 or 4 of these beasts.
Killer price for the surge inductive load capabilities.
$1473 with code, these retailed at about $3200,
/ 10kW Ground Mounted Solar Panel System #30
750 watt? those must be Huge panels. The 450's I have are 7' long how big is a 750 watt panel? Hope you are strong mounting these 68lb. units was enough work for me.
I would hurry or hold off not sure which?. Another announcement today about new Tariffs but for Asian non China homeland imports.
/ 10kW Ground Mounted Solar Panel System #31
If you get any appreciable amount of snow where you are located, I would suggest looking seriously at seasonal tilting of the panels. They will shed the snow much better if tilted to about 65 deg off horizontal. And of course you will get better yield too. If you leave them with a 45 deg or so tilt, they could sit for a long time covered in snow. I see that around here on some of the big commercial installations. And don't forget to keep them high enough off the ground to stay above snow level, and above any piles of shed snow. The bottom edge of mine are about 5' off the ground.
/ 10kW Ground Mounted Solar Panel System #32
I would imagine the long stretches of overcast you get in the PNW would put quite a damper on solar production.
/ 10kW Ground Mounted Solar Panel System #33
We have 7.2KW (25 LG Neon 300W) panels on the garage (separate service entrance) since December 2014 and we just hit 77MW (average 7700KWH/Year) with net metering we over-generate but they pay us the current rate for excess power. Payments are taxable over $600 a year - they send us a 1099.
Our array was $3.65 a watt in 2014 installed $26K then tax credits and rebates of $13K and electricity at $.18 a KWH the ROI was 8.4 years.
Yes, it's "free money now" vs paying for the power.
/ 10kW Ground Mounted Solar Panel System #34
My grid-tied system (no battery back-up) here in VT paid for itself in 8 years. I did save a bit by helping with some of the labor on the install.
/ 10kW Ground Mounted Solar Panel System #35
The term for how much sunlight you receive is "insolation." The National Renewable Energy Laboratory publishes an insolation map of the US (and world) at NSRDB
The unit they use for the map is average kWh/m2/day. I find a more useful measure is equivalent hours per year, because you can multiply that by the rated output of a panel to get kWh per year; multiply that by your electric cost to get dollars per year. It's helpful to know that panels are rated at a solar intensity of 1 kWh/m2, so one kWh/m2/day is equal to one hour per day. So if you take your average from the map and multiply by 365 you get expected hours per year.
The map shows Rhode Island in the 3.0-3.5 kWh/m2/day band. As I noted earlier, in the past 12 months I got the equivalent of 1200 hours of sunshine, which would mean an average of 3.28 kWh/m2/day. And solar pays for me, mostly due to high electric rates and generous net metering policies. The Pacific Northwest has about the same level of insolation, but my understanding is electricity is cheaper there so it might not pay to go solar.
Parts of the southwest have double the level of insolation I see.
/ 10kW Ground Mounted Solar Panel System #36
Or you could just use PVWatts to do the calculation for you:
/ 10kW Ground Mounted Solar Panel System #37
West of the Casecade mountains, yes. Except for the an area in west puget sound that is in the weather shadow of the Olympic Mtns.
East of the Casecade mountains there are some locations that get 300 days of direct sun, enough to keep a solar system running without the need for a generator for off-grid systems.
/ 10kW Ground Mounted Solar Panel System #38
Hmm. I did the calculation, and it gave me average daily insolation of 4.96 kWh/m2 and an annual equivalent of 1410 hours of sunshine. Those two number don't agree with each other and are quite a bit higher than what I'm actually seeing.
/ 10kW Ground Mounted Solar Panel System #40
The outgoing administration just recently added tariffs back on biracial panels. They were exempted for a while. Might explain the good pricing.
I saw a video from Germany, where they experimented, and found vertical mounting actually gave the best daily output with biracial panels.
The drop in efficiency at peak hours was more than compensated by early morning and evenings.
It also eliminated snow loads.
John Deere Z994R (A60462)
John Deere Z994R...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59910)
2020 VOLVO VNL760...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2011 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A63569)
2011 ORTEQ ENERGY...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
