Bent pins: fix or replace?
/ Bent pins: fix or replace? #1
halfBaked2024
No cattle
I guess it doesn’t take much to bend the isolation pins for the boom and swing arm on a BY85 backhoe; it seems TYM may have made these with softer metal on purpose.
Would you guys bother looking for a machine shop with a press to straighten them back out, did you buy your own press or do you keep a few spares?
/ Bent pins: fix or replace? #2
Have you checked already? ...because I wouldn't expect basic pins to be too expensive...
/ Bent pins: fix or replace? #3
I would look into what replacement OEM pins cost. Also why did the pins get bent in the first place? Might want to figure out the cause prior to investing in new.
This could have happened during shipment. I didn’t force any hydraulics too harshly when pulling them, but I do admit I was a first-time operator when removing them… figured it was me and they must just be really soft metal.
Doesn’t appear to be any damage and machine works great. 🤷
I’ll see if I can slide them back into place like they are now and that might indicate it happened during shipment.
/ Bent pins: fix or replace? #6
My experience says straightening pins is pretty easy job if they aren’t bent to bad and you have a decent press.
/ Bent pins: fix or replace? #8
My TYM backhoe is a larger model than yours, but I broke the lockout pin on mine as well. Welded that pin back together (needed the welding practice). It broke again (still needed more welding practice!). Bought a new pin from Tractor Supply... it hasn't broken since.
/ Bent pins: fix or replace? #9
Consider yourself lucky. There have been reports of housing being broken rather than the pins breaking or bending...on Kubota backhoes.
With my backhoe, I have forgot to remove locking devices, one is a pin that I never use for swing, and the other is a strap that locks the boom. Years ago, the pin on the boom got pulled out when I forgot about it. But I welded it back in with some reinforcement, and it had worked flawlessly since. As tested many times over the years.
Each design is different, of course...
I think the pins are a softer material by design. I have a unique redneck idea I’m going to try and will post back here. 🤞
/ Bent pins: fix or replace? #11
/ Bent pins: fix or replace? #12
I have mine bent, hit it with the hammer a couple of times and all good now. Don't overthink it, they are soft for a reason. You don't need a press
/ Bent pins: fix or replace? #13
I always want the easiest to replace, cheapest, part to break first. I would think that pin is very easy to find and rather inexpensive to buy.
I can’t find these same pin sizes to save my life!
BY300-240001 - 25mm dia X 90mm long (~1” x 3-1/2”)
BY400-440000 - 20mm dia X 215mm long (~3/4” x 8-1/2”)
There seems to be every size in these diameters except what I need.
Dealer came back with $126. 😮
Without a press, I have this redneck idea to carefully use my log splitter with some blocking. I’ll let you guys know how it goes!
/ Bent pins: fix or replace? #16
My tactic on this is the same for all my part alteration experiences. I buy new ONCE, then fix, or have fixed the broken or bent part(s). So, I pay for the crime and have a replacement on-hand when needed ASAP. I do learn the lessons, though, too.
/ Bent pins: fix or replace? #17
Have you tried a hammer? Works better than breaking your splitter
/ Bent pins: fix or replace? #19
Why not just buy a stick of the correct diameter drill rod (which will come polished) and cut to length and be done with it. Should be a whole lot cheaper,
/ Bent pins: fix or replace? #20
Drill rod will work-harden and break instead of bend.
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2012 CHEVROLET SILVERADO 1500 (A67714)
2012 CHEVROLET...
TANK MANIFOLD (A67714)
2012 DRAGON 165BBL ALUMINU VAC TRAILER (A67714)
2012 DRAGON 165BBL...
CAT 963D 4-in-1 Bucket (A68134)
CAT 963D 4-in-1...
2007 CHEVROLET SILVERADO 1500(INOPERABLE) (A67714)
2007 CHEVROLET...
