Bent pins: fix or replace?
/ Bent pins: fix or replace? #21
I use a 5 lb hammer but don't use full force
I don't want shaft bend the opposite way
willy
/ Bent pins: fix or replace? #23
No, it won't unless heated to the prescribed hardening temperature.
Brass work hardens, drill rod don't.
Retired after 40 years as toolmaker, I won't argue the point.
/ Bent pins: fix or replace? #24
Good, I happen to own and operate a short run tool and die and heavy fabrication shop. I deal with all types of steels and other alloys every day and I have my Journeyman's card in T&D as well and I'm certified in TIG welding in exotic alloys too.
Oil hardening or air hardening drill rod remains ductile until it's heated to the hardening temperature specified and then quenched or cooled by other (external) means.
A pin in an assembly isn't subject to heating last time I checked.
He could always just buy a mild steel round that has been ground as well.
/ Bent pins: fix or replace? #25
At the end of the day, why use the swing lock to begin with, unless transporting the tractor on a trailer or other vehicle?
After 24 years, I had to go look at my backhoe, to be sure there was a swing lock pin! There is one!...Never felt the need to use it around the homestead.
Am I the exception here?
Now the boom lock, I use all the time. Different animal...
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
2012 Infiniti G37 Sport (A62613)
2012 Infiniti G37...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
