Ford eco boost
/ Ford eco boost #41
My area in Texas has seen what you say. The Ford dealer in the small town will probably close it doors forever soon.
Sounds to me like Ford has decided to send every truck built on a hangover-Monday to your area of Texas.
Just the opposite here in northern Nevada/southeast Oregon. There is a Ford dealer in every little town. If you want a GM or a Ram you have 3 options. Reno. 500 miles to the south in Las Vegas, or 300 miles to the east in Elko Nevada.
And you'd better get used to the idea of a small turbocharged engine in a pickup truck. Our fearless leaders in Washington are forcing all the manufacturers to them. Can't buy a V8 Ram half ton or Toyota Tundra anymore. GM is working on their version also.
/ Ford eco boost #42
The only aspect of the Eco-Boost engine that I've read about is, you need to change the motor oil every 5K miles and not use the built in oil minder and change at 10K. The extended change intervals (from what I read on various forums) is death on them.
In reality, I change the motor oil in our vehicles at 5K anyway. Oil is cheap compared to engine repairs.
/ Ford eco boost #44
I know people that own one and my general feeling is they are a solid engine no more likely to be a problem than other engines.
Exactly! All the newer engines are a lot more complicated than the old pushrod engines we were used to. You can read all kinds of horror stories about the problems caused by the cylinder deactivation systems in GM and Ram engines. Or the dual battery system in newer Jeep Wranglers.
All these crappy unreliable unnecessary features added to good engines to meet some government "standard".
/ Ford eco boost #45
I still prefer and always will, a V8 versus a tiny motor in a truck or a large SUV. My wife's Burb has a V8 and while the mileage isn't great, at least it has plenty of engine to haul it's weight around.
My Ford Focus RS has a 4 banger in it, but it's light to begin with and the hairdryer on it makes 320 ponies. Sleeper supercar.....
My ongoing philosophy will always be, there is no replacement for displacement in any vehicle that weighs a substantial amount. Consequently, an Eco Boost 4 banger in a full sized truck will always be a non starter for me.
/ Ford eco boost #46
One thing I’ve learned on Internet forums is people don’t come on a forum and say my truck, tractor, car is great. They come on a forum because something is wrong. You can Google just about anything, say problems with Bic Pens and you’ll get a bunch of hits on all the things wrong with them.
/ Ford eco boost #47
My neighbor's had a Ford Escape with an ecoboost in it. After two motors, and under 100k miles, they went with imports for them both. One a Subaru and one a Toyota.
/ Ford eco boost #48
couple years ago I bought a 2012 f 150 had low miles , have 142.000 on it now just got out of the shop $4000 worht of repairs , timing chains and all the bs that goes with it anyone else had good bad experience with one ?
I have a 2013 F150 ecoboost. I had the first timing chain stretched and needed to be replaced at 60,000 kms. Thankfully it was under warranty. Now the truck has 174,000 kms and now the stupid timing chain is stretched yet again and needs to be replaced. This time not under warranty unfortunately, which is going to be a huge repair bill. I am so angry about this. Clearly this is a poor design with so many other ones having failed and now it has failed again. I was going to buy the 6.2L at the time and salesman talked me into the ecoboost. I am so pissed off I listened to him. I do not drive this truck hard at all and barely tow anything at all. It is absolutely ridiculous the timing chain is stretched yet again, which means once I replace it then it just a matter of time before it gets stretched again. Piece of junk ecoboost.
/ Ford eco boost #50
They dont stretch, they wear and its from poor quality oil/ or long oil change intervals.
/ Ford eco boost #51
I thought long and hard about whether or not to go with the 3.5 Ecoboost in 2013 when I bought my F150. I was leaning toward the 5.0 mainly because I thought it would last longer. I knew I did not want a Ram after my 97 fell apart. I won't go into details. My 2013 F150 4x4 has 270k miles. The only issue other than routine maintenance I've had was a valve spring broke at 61k miles. The dealer got Ford to cover it. I'd had all my service done there, and they told me that should not happen. Cost me $200 instead of $3500. This has been the best truck I have ever owned. I'm skeptical about the new ones. All the extra mile to the gallon tweaks with the 10 speed transmission and the cyllinder deactivation add too much complexity. I recently drove a 2.7, 3.5, and a 5.0 back to back. The 2.7 surprised me and was not bad. The 3.5 took a second for the turbo to wind up, but was very strong after it did. The new 5.0 was a beast. I'm getting closer to buying again and am starting to see deals locally that I have not seen in years. People are running out of money I guess. My 2013 was $11k off MSRP when I bought it. I asked about cyllinder deactivation on the 5.0 and did not really get an answer. I am now trying to decide between the new 5.0 and the 3.5. I'll bite some time in 25 if the right deal shows up.
/ Ford eco boost #52
Y'all are lucky so far. I have read that the Ford ecoboost to treat it like the plague.
Common issues with Ford's EcoBoost engines include: carbon buildup on intake valves due to direct injection, intercooler condensation, timing chain stretching, ignition system failures, coolant leaks, turbocharger problems, and potential issues with cam phasers;
Nah, almost none of that is true for the 2nd gen 3.5L EcoBoosts engines built from 2017 onward - except for the Cam phasers.
My 2019 3.5L is at 70k miles now (bought used at 54k miles) with zero cam phaser noise on the original units. I intentionally do a "flood start" to build oil pressure before letting the engine fire, anytime it has been sitting for more than 8 hours or so. But I know the phasers may still fail eventually, and that repair not fun to pay for, and is so complex that it often causes extra trouble. Zero check engine codes or trouble of any kind since I bought it.
I tuned my truck with an SCT tuner and their off-the-shelf 91 octane tune (I run 93) and it is insanely fast. Getting ~21mpg summertime, ~19 mpg fall-spring in mixed suburban driving.
/ Ford eco boost #53
Exactly and last time I checked, timing chains had no brains so they cannot be stupid. I watch the YT channel 'I do cars' a lot and they tear apart all sorts of engines and every one where the oil was neglected, the insides of the engines look like hell.
Modern multi grade synthetic motor oil likes making sludge and staining engines internally.
/ Ford eco boost #54
Ive never heard the term "flood start". What is it?
/ Ford eco boost #55
I get 21 out of my '97 7.3 turbo diesel average and my diesel will be running fine when yours is at the scrapper.
/ Ford eco boost #56
the cam phaser issue was resolved during 2019 builds, ive been told. ford has extended warranty for that issue past original warranty. mione was assembled later 2020, so hopefully im free of all that junk. i like my 3.5l unit. has great power and response. extremely happy with it, but i did delete that stupid engine stop switch when idling at stop lights, etc.
/ Ford eco boost #57
Of course all of these problems stem from our
trusty govment sticking their nose in things they don't have the knowledge to know what they are doing except to cost the tax payers more money for all the crap they have to add to the vehicles if they would just let the engineers figure out what is needed we would probable have vehicles with a lot less problems
willy
/ Ford eco boost #58
i do miss my old 1975 F350. i could climb into engine area with hood up to work on it. sooooo much room. i wont touch any of my newer rigs.i have a good and trusted mechanic for that. heck, there so crammed with junk, i cant even trace a spark plug wire.
/ Ford eco boost #59
My timing chain was done around 210,000 km (130,000 miles) Independent shop did it for under 3K. Mechanic thought motor had never been touched before that. The chain was well worn, tensioner was fully extended, but the truck ran well enough to tow. Was throwing codes and had boost lag bad.
Oil change ever 5-6000 km with full synthetic, ignore the oil life thing in the dash.
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
2011 Chevrolet Impala Sedan (A66738)
2011 Chevrolet...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A67714)
2015 VANTAGE...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A66734)
2025 Kivel 42in...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
